Question about Sanyo VPC-X1250 Digital Camera
My laptop dont recognize the sanyo x1250
Cant upload the pictures off my camera.. because my laptop is not recognizing it
Posted by amanda on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sanyo Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Posted on Mar 04, 2012
1 Related Answer
It wont connect with my computer
Search Results
    My laptop does not recognize my mp3 player [Solved] - CCM
    ccm.net > Forum > Hardware > Laptop
    Jan 18, 2013 - Connect the player, open device manager, right-click on WALKMAN under .... my sony mp3 walkman,my computer dont recognize it,i cant upload my .....Does not charge. is not recognized by windows media or My Computer. My computer does not recognize my mp3 player.
    Nov 16, 2014
    I cant get my songs to my mp3 player
    Oct 11, 2013
    Sony Mp3 Walkman is not getting Detected !
    Oct 31, 2012
    More results from ccm.net
    My PC does not recognize my MP3 player - CCM
Jan 06, 2016 | Audio Players & Recorders
Usb device not recognized
Assuming a healthy camera battery, capable of holding a charge - try another cable / USB port / Computer first.
When it's same on all USB ports and a different computer, wiggle the USB connector on the camera carefully. If the connection is ok at some point, it's the camera USB port making bad connection.
Jul 04, 2011 | Sanyo VPC-X1250 Digital Camera
I have a VC-S1414 digital camera and can't get my computer to recognize the camera. Any suggestions. I have turned it off and back on, I have changed the usb location on the computer and still nothing.
if you have a memory card , removed the memory card then put it in your card reader in the pc. so that you can upload your picture or try to download the installer of your camera sothat it can recognized your pc.
Mar 14, 2011 | Sanyo Cameras
Cant upload pictures to my computer with samsung tl220,cant even see an icon foor it.
I had the same problem with a new Samsung TL220. I would plug cord into computer and camera. It would not recognize camera but would charge camera. After 25 minutes with tech support, they said it was the cord and the sent me a new one. Problem solved
Jan 31, 2011 | Samsung DualView TL220 Digital Camera
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Nov 30, 2010 | Cameras
I cant upload pictures from my polaroid t730 camera to computer
I can'tg upload pictures. I have a polarioid t11031 digital camera, and I have a USB cord ffor it, but my computer does not recognize it when I plug it in. I want to know how I can get the pitctures off my camera and onto my computer.
Aug 10, 2009 | Polaroid T730 Digital Camera
I CAN'T UPLOAD MY PICS WITH THE NEW CAMERA I PURCHASED BECAUSE MY COMPUTER IS NOT RECOGNIZING THE SANYO DISC THAT CAME WITH IT.
If your using the camera with a sd card and you have a sd slot on your computer you will not need a disk. Just insert the sd card to the computer go to start > computer> then click on the sd card and the pictures should be there.
Jul 07, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Sanyo VPC-X1250 Digital Camera Logo
71 people viewed this question
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
