If i hit the tv it sometimes fixes it
If hitting the TV sometimes corrects the problem then usually there are some bad solder connections. As the sets heat up and cool down the pc boards slightly expand and contract, where a component leg sticks through the board and is soldered on the other side a small crack will develop around the solder connection. Sometimes they are easy to see, sometimes very difficult. One way to narrow down where the bad connection is, being very careful because of dangerous voltages, using something non conductive lightly tap different parts of the pc boards to see what area is most sensitive, then you would need to unplug the set and get to the bottom of that board and look for the bad connections.
