Question about KitchenAid Pasta Roller / Cutter Set
KitchenAid KPRA Brass input shaft sheared. Need a replacement
9mm Brass allen wrench cut to legnth (About 1 Inch) would work nicely. Replacement part would be ideal.
Posted by navdude30 on
  • navdude30
    navdude30 Sep 08, 2012
    Yea, Someone destroyed my worm gear long ago. I recall it costing a Lot more than $5.85 when I replaced it. Until I find a suitable replacement like you mention above, I robbed the shaft out of the Spaghetti roller. It's slightly different in design, but it works for now. Because I have a temporary replacement in place, It has not been a priority of mine to repair. Maybe that's something I should look into now that you have reminded me :D
  • Brad Sep 09, 2012
    I used to buy them for under $6 all the time. On Amazon.com they range from $.50 to $12.
Jeff Woodward
    New Friend:
The "brass input shaft" is designed to break in the event of too much torque being applied; it acts as a shear pin. For safety considerations, I would be careful what I used to replace the shear bolt/shaft. Failure of the shear bolt is necessary to prevent more serious damage to either: 1) the mixer, 2) the pasta attachment, and perhaps most importantly 3) the object stuck in the pasta attachment (think of ingested clothing, hair, fingers, etc). Unfortunately, KitchenAid refuses to supply replacement shear bolts (and I couldn't get an answer as to why); however, they seem pretty good about replacing the attachment under warranty. But logic dictates that a part, such as a shear pin, that is designed to fail, will have a high probability of breaking long after the warranty period has expired. To that end, I have machined a bunch of spare shear bolts to the same physical dimensions as the original part out of 5/16" brass hex stock. I would consider making some available to others in need at a nominal fee.
Posted on Mar 14, 2012
  • 12 more comments
  • chichyo
    chichyo Mar 27, 2012
    how would one get this from you & how much would they cost ?
  • Kacman12 Sep 04, 2012
    Are you still offering this part and at what price?
  • Jeff Woodward
    Jeff Woodward Sep 10, 2012
    I have a few leftover that I can share with a friend or two in need. Is $5.00 + $2.00 S/H reasonable?
  • cd_meitzler
    cd_meitzler Sep 24, 2012
    I would also like to purchase this piece, if still available?
  • Jeff Woodward
    Jeff Woodward Sep 24, 2012
    My email is jeffrey dot woodward at gmail dot com. Email me some contact information, and I'll get one in the mail to you.
  • Hector
    Hector Oct 26, 2013
    I have emailed you for a replacement... :) Thanks...
  • stuart chase
    stuart chase Jan 23, 2014
    I am having the same trouble and would be happy to buy a few off of you. Also, I can't get the broken shear pin half out of the nylon gear plug. don't suppose you make those, too?! I can be emailed at stu dot chase at gmail com com
  • E kyron Thibodeau
    E kyron Thibodeau Jul 25, 2014
    So I made the same mistake as 1020319 users and blew the shear pin while cleaning the rolling rollers with a damp cloth. Anyone here know/has a resource to get a replacement pin?
  • TommyWoj
    TommyWoj Sep 04, 2014
    I was more creative than the damp cloth method. I was using a stainless steel cocktail pick to knock loose some dried pasta near the edges of a spaghetti roller. Lo' and behold, I watched in horror as the cocktail pick -- ever so slightly larger in diameter than a spaghetti slot -- get sucked into the rollers, get jammed and then the shear pin did what it was supposed to do. Now working on the fix.
  • Star Pickrell
    Star Pickrell Nov 24, 2014
    How can I get a shear bolt?
  • Palvin Chan
    Palvin Chan Dec 27, 2014
    Hi All,
  • Palvin Chan
    Hi All,
  • Palvin Chan
    Hi All, here is a soultion to fix your kitchenaid pasta attachment!http://www.ebay.com/itm/KitchenAid-Pasta...
  • Jeff Woodward
    Jeff Woodward Dec 31, 2014
    Looks like genuine replacement parts may be available search for the following part numbers: part numbers! Roller: AP5690822 or W10520825. Cutters: AP5691965 or W10520823. NOTE: I HAVE NOT ORDERED EITHER USING THESE PART NUMBERS, but they do appear to be correct.
Nate
    New Friend:
It is actually really simple to fix, but you run the risk of damage to the mixer should you put a load on it again. Undo the three Phillips screws (the small ones around the shaft). Do NOT undo any of the other screws or you will spend an hour trying to fiddle lining up everything to fit together. Next, get a pliers with teeth. A vise grip will work dandy too. Now, grab the nylon pin and pull outward. It has a flat bottom that was designed to pull out the broken sheer bolt. Next, take the top, longer broken piece, and place it where the short piece was (remember to put back in the nylon pull plug). Just enough nut will be outside of the nylon gear that the mechanism can grab on to. Screw it back down an you are making pasta again.
KitchenAid KPRA Brass input shaft sheared. Need a  - c26570b0-2aea-4194-bed8-ceb4cf4aa059.jpg
Posted on Jan 01, 2013
  • 4 more comments
  • Stephen Miller
    Stephen Miller Nov 12, 2013
    Dude you are a genius. That was the easiest fix I have ever dine. Especially after stressing over getting a new one or drilling out a hole in the middle of an allen wrench or something else. BAM, done in seconds and making spagetti.
  • Ralph Mohles Dec 22, 2013
    Thanks for this hint. I pushed the brass pin out of the nylon gear until enough pin was outside.
  • Nate
    Nate Dec 27, 2013
    I am very happy to help you guys out! I had to laugh at Brad's solution where you can lost a neck tie. My question is why you are making pasta while wearing a tie? I do agree though that you can lost a finger, but I would argue that a lot of things can take your finger off, like a circular saw. The key is to be careful!
  • Nate
    Nate Dec 27, 2013
    Please note that the photo I provided is to show you what the inside of the unit looks like. Please do NOT take the whole thing apart as it is a bear to get back together.
  • Joe S
    Joe S Jul 10, 2014
    Not only is it a bear, I have not yet been able get it done successfully. Is there a trick or procedure that will help me to get it back together. The tabs on the ends of the wipers and covers make them too long to fit into the slots that hold them when the throughbolts are in and the nut has been started to thread on. I'm ready to give up. Thanks for any input. .
  • Palvin Chan
    Hi All, here is the replacement part for the kitchenaid pasta roller.http://www.ebay.com/itm/KitchenAid-Pasta...
anon
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Here's my solution. I purchased an 8mm zinc-plated brass hex standoff from http://www.mcmaster.com (part number 92080A053). It is 25mm in length and has internal threads for an M4 screw. It fit perfectly into the nylon gear plug without modification. I had a colleague from work bore out a hole with his drill press (removing the internal threads) and turn down the exterior with a lathe to create a weak spot (mechanical fuse). See the attached image for the finished product. It doesn't match the original dimensions exactly but it is close and will suffice. You don't necessarily have to do the extra machining work if you don't have access to that equipment, but as jeffrey_w325 states in his post, this part is supposed to be the weak link and fail first. If you don't machine the part down, just be extra careful when using the pasta attachment. Good luck!
Posted on Apr 03, 2012
  • 1 more comment
  • Joe Meyer Sep 21, 2012
    How did you guys get that nylon gear plug out? I got down to the four nuts with the bolts in the sleeves underneath the plat and could only get two off. Does that plug pop out somehow, or am I missing some easy way to turn those last two nuts without the bolts turning underneath?
  • cd_meitzler
    I am having the same issue. Do you have to bore the brass out and remove the plastic? How did you go about this?
  • Vince Asaro Jul 03, 2013
    Hi, I got in touch with Jeff Woodward and here's the instructions to remove the shear pin he kindly provided: "Drill a small hole in the backside, rest the nut portion of the gear in a socket, using a punch and hammer, knock the old pin out putting the punch through the hole that you drilled. They don't come out of that gear easily. I used a 1/8" drill and drilled roughly 3/16" into the backside and used a nail because I did not have a punch. .Hope that helps you out. Vince.
Palvin Chan
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 9 Answers
Hi All,
Here is the solution to fix your kitchenaid pasta roller attachment.
http://www.ebay.com/itm/281539451678?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Yes, it is frustrating that Kitchenaid won't provide replacement parts that are supposed to fail. Replacing the entire attachment just seems like a wasteful solution!
Cheers,
[email protected]
Posted on Dec 24, 2014
  • 1 more comment
  • Palvin Chan
    Palvin Chan Jan 10, 2015
    Here is the replacement parts for the Kitchenaid Pasta Cutter.
  • Palvin Chan
  • Palvin Chan
    http://www.ebay.com/itm/281557731216?ssP...
Brad
    New Friend:
  • 10 Answers
FYI... Used to repair these for years at California Electric Service in the late 80's The mixer has a nylon Worm Gear which costs $5.85. It serves the same purpose to protect in case of too much torque vs. a jam up of some sorts.
The shaft on the pasta maker is a double redundancy.
It fails too easily. Replace it with a 1" x 9mm hex slug available at any decent hardware store. about 75 cents total. The worm gear would fail in case of a jam and can be replaced in less than 10 minutes.
Just be careful with the pasta maker. Despite the fail prone shaft, you can still lose a neck tie or flatten a finger way too much before the shaft would ever fail
Posted on Sep 08, 2012
  • 1 more comment
  • Christopher French
    Christopher French Mar 24, 2014
    We were able to repair ours with a 8mm hex socket and extension from Home Depot - we knocked the hex extension out of the socket and used that to replace the broken shaft. Had to press the old shaft out of the nylon insert as described below. Thanks for all the info - would have scrapped it otherwise.
  • Palvin Chan
    Hi, you may run the risk of damaging other comonents in the mixer and /or pasta attachment. Here is another solution.http://www.ebay.com/itm/KitchenAid-Pasta...
  • Kathleen McGregor
    Kathleen McGregor Mar 26, 2015
    Can I just say, I thought California Electric was the best. I mourned when the store closed. There are fix-it guys doing something called Repair Cafe now. People are realizing the value of fixing over throwing away.
Bert Wills
    New Friend:
Here is the answer to your problem. The part number for the sheared coupler is W10520825. It is around $ 10.00 and is available in Canada from Whirlpool parts. If you need assistance send me an email.
Bert
Posted on Dec 31, 2014
  • Jeff Woodward
    Bert, That's awesome! As you suggest, the part is available from the sears parts website as well:http://www.searspartsdirect.com/partsdir... HOWEVER, this is the part for the ROLLER. The cutters take a slightly different "coupler" shaft. Do you happen to have the part number for it? If you don't mind me asking, how did you acquire the Whirlpool part number in the first place. Obviously, a lot of people (including myself) attempted to find the part to no avail.
  • Jeff Woodward
    I may have found it! W10520823. Both parts appear to be available on the searspartsdirect website and athttp://www.appliancepartspros.com/attach... There may be plenty of other sources. The key was your brilliance in finding actual part numbers! Roller: AP5690822 or W10520825. Cutters: AP5691965 or W10520823.
karinto
    New Friend:
Here's my solution to broken shear pin.
After trying calling KitchenAid who won't fix or send a replacement part, I tried several things that didn't work. Then I thought I'd take apart the fettucine cutter and spagetti cutter. The mechanism is not exactly the same but the shear pin is the same size. Now to get the right fitting into the pasta roller side. I tried several things that didn't work, then I went to Home Depot looking for some rubber or plastic device that might work, and then I thought of a plastic tubing that would fit over the bolt and be flexible to grab the mechanism inside the roller. I found clear vinyl tubing 1/2" x 3/8" x 20 ft. ($9.00) They don't sell small pieces. You only need about 1". Cut off this length. Insert all but 1/4" into the roller (tight fit), then insert the shear pin from the fetuccine cutter, another tight fit, but it has to be to get a good fit. Put your roller back together and give it a test.
Posted on Mar 13, 2013
  • 1 more comment
  • Tracii Reardon
    Tracii Reardon Jan 05, 2014
    THANK YOU!!!!!!!! Brilliant suggestion.... I guess that's why we have these meetings ...LOL
  • Tracii Reardon
    Tracii Reardon Mar 07, 2014
    Didn't last long :(
  • Palvin Chan
    Hi, try this! Replacement hex shear shaft for the kitchenaid pasta attachment.http://www.ebay.com/itm/KitchenAid-Pasta...
Bob Pfeiffer
    New Friend:
Its hard to get the broken shaft out of the nylon collar because there is a groove cut into the shaft. The nylon collar has a ridge inside that fits into the groove to lock it into the collar. You can see the groove in the photo Anon posted. Rather than risk cracking the collar use a thin coping saw blade to cut along the length of the collar, that will allow you to pry it open and get it off. I just finished my repair.Works great.
Posted on Mar 07, 2014
  • Palvin Chan
    Hi, here is a complete replacment part for the kitchenaid pasta attachment. The hex shaft comes with everything you need to get it working.
  • Palvin Chan
    Add a Commenthttp://www.ebay.com/itm/KitchenAid-Pasta-Roller-Attachment-KPSA-Repair-DIY-Hex-Shear-Shaft-Replacement-/281539451678
Jim Lu
    New Friend:
Can you make video and post in YouTube for everyone? Sounds like lots people had same problem.
Posted on Jul 09, 2013
  • Tracii Reardon
    That would help a lot!
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
Kitchen aid pasta roller
Hi, you may have a broken shear shaft. Here is a link to replace it.
It also comes with instruction on how to replace it.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
We need to find a part number, the hexbolt which is inside of the pasta roller/kitchen aid attachment
Here's my solution. I purchased an 8mm zinc-plated brass hex standoff from http://www.mcmaster.com (part number 92080A053). It is 25mm in length and has internal threads for an M4 screw. It fit perfectly into the nylon gear plug without modification. I had a colleague from work bore out a hole with his drill press (removing the internal threads) and turn down the exterior with a lathe to create a weak spot (mechanical fuse). See the attached image for the finished product. It doesn't match the original dimensions exactly but it is close and will suffice. You don't necessarily have to do the extra machining work if you don't have access to that equipment, but as jeffrey_w325 states in his post, this part is supposed to be the weak link and fail first. If you don't machine the part down, just be extra careful when using the pasta attachment. Good luck!4_3_2012_1_04_19_am.jpg
May 03, 2011 | KitchenAid Pasta Roller / Cutter Set
What size allen wrench is needed to remove the Front Brake shoes on a 2002 Dodge Durango ?
I just did my front brakes yesterday and it needed a star drive ( torx wrech ) bit, not an Allen wrench
Jun 11, 2010 | 2002 Dodge Durango
Teeth sheared off the coupler drive on KitchenAid Blender
You should be able to remove this assembly from the other parts - then you will have enough room to work on it.
Remember to clean the seal area if disturbed or it may leak.
Aug 20, 2009 | KitchenAid KSB560 5 Speed Blender
Broken shear pin in kitchenaid A9 Coffee Grinder
I was able to find 3/32 x 1/2 inch spring pins at a local hardware for 13 cents each. They may not last as long, but at the price I can replace as needed.
I also had to disassemble twice; I didn't notice that a portion of the old pin was wedged in the underside of the burr. When I put it back together the first time, the new pin rested on the old fragment and pressed the burrs too close together. On the coarsest possible setting, I got coffee powder!
Final note: The nut for the cap over the burrs is reverse-threaded...use a wrench on top, and a flat-blade screw driver in the slot at the bottom of the motor shaft.
Jan 01, 2009 | KitchenAid A-9 Electric Burr Grinder
KitchenAid Pasta Roller / Cutter Set Logo
12,041 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
