Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
Stevan Milanovic
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
so on my graphing calculator i put my equation x^3 - 3_4_2012_7_04_47_am.jpg
As you can see this function have zero values in the points -2, -1 and 4
Posted on Mar 04, 2012
5 Related Answers
Anonymous
SOURCE: my graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
Posted on Jul 15, 2009
k24674
  • 8091 Answers
SOURCE: WHen trying to graph anything, ERR: INVALID DIM
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Posted on Oct 16, 2009
k24674
  • 8091 Answers
SOURCE: ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Jan 16, 2010
  • 102366 Answers
SOURCE: Not Graphing
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If that's not it, post a comment and we'll go from there.
Posted on Apr 08, 2010
k24674
  • 8091 Answers
SOURCE: Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
Posted on May 12, 2010
When I try to graph it says-ERR:INVALID DIM 1:QUIT
Nov 01, 2013 | Texas Instruments TI-83 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
I hit the y= button and then just put on 2x+8 and hit graph and then it will read err:invalid dim
Correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Oct 28, 2010 | Texas Instruments TI-83 Plus Calculator
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
My calculator will not graph the equations i put in under the y= button. it says "ERR:INVALID DIM 1:QUIT"
Oct 25, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Im trying to graph an equation and my Ti-83 says Err:Invalid DIM
May 05, 2010 | Texas Instruments TI-89 Calculator
Will not graph
Having gone over a month without a response, I assume turning off the stat plot features did the trick.
Apr 14, 2010 | Texas Instruments TI-83 Plus Calculator
I am trying to graph an equation and the following appears when I hit graph: ERR:INVALID DIM 1:Quit Do you know how to fix this? The same error comes up when I try Y=X
Feb 07, 2010 | Texas Instruments TI-83 Plus Calculator
I put the equation into y= and then i hit graph. when i do, the screen comes up as ERR: INVALID DIM. help i need to graph!
dont you have to chose if its quadratic or not? I'mnot 100% sure if thats right my calculator isn't working so i cant check if thats what your doing wrong ir if thats for something else
Jun 15, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
165 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
