Question about Ricoh Aficio 1515 Black and White Copier
Tenho uma maquina ricoh aficio 1515 que esta a dar me erro 144 , nao sei como resolver esse erro .
4 Related Answers
Anonymous
  • 263 Answers
SOURCE: tenho uma ricoh 171 esta
You have a main motor overload. This can be caused by a defect in the photoconductor unit. Try putting an old photoconductor unit. If you still can not run the engine is broken
Posted on Jan 18, 2011
Anonymous
  • 263 Answers
SOURCE: TENHO UMA RICOH 161 E
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Posted on Mar 01, 2011
Anonymous
  • 263 Answers
SOURCE: I have a Ricoh 161 but after a firmware update
You can not stop a firmware update.
Did you turn the machine off while the firmware update? If you did that your NVram is broken
I think that the only chance you have is with a new NVram. Sorry but you will have to put a new NVram.
Posted on Jun 10, 2011
gausen_1
Gausen
Hello.. i have the soluction for you. You can use the same NVRAM. I can help you.. i dont know how long time ago you posted it. If you need my helper, send me a e-mail. [email protected]
1 - you need a new firmware. try do make a download from internet
2 - save the firmware update in a SC card
... i tell you the rest if you need
Posted on Jul 10, 2012
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
2answers
I have a Ricoh 161 but after a firmware update erro (NIB) the machine tries to continue the update. How I cancel the firmware update or reset the firmware in the machine? ----------------- Eu tenho uma...
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
1helpful
Sc 335 da Ricoh 1075, como solucionar?
Olá!
Esse erro está relacionado com o Motor Poligonal do Laser.
Antes de mais deves actualizar o firmware da maquina. Existe uma referência que corrige esse sintoma.
Se depois da actualização o problema persistir poderá ser 1 destes problemas (por ordem de solução):
1-Mau contacto nos cabos do Motor Poligonal.
2-Motor Poligonal avariado.
3-Placa IPU avariada.
Espero ter ajudado.
See you!!!
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Boa sorte.
1helpful
Tenho uma ricoh 171 esta dando erro sc500
3helpful
2answers
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Tenho uma sharp AL-1655CS que diz ERRO SISTEMA [H4-00] Auguem sabe me dizer como resouver???
Dear Sir
h4 signal is copier fuser unite problem
such as thermostator or heater lamp is broken or burning
Ricoh Aficio 1515 Black and White Copier Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Ekse
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
