Question about Ricoh KR-30SP 35mm SLR Camera
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Posted on Dec 14, 2008
SOURCE: sears ks-2/ricoh xr-7 film advance and shutter release problem
You probably need to take the camera in for repair. It sounds like the film transport is not connected to the shutter/mirror cage ***'y.
Posted on Feb 03, 2009
SOURCE: My Ricoh KR-5 won't keep the film door closed. How
The film doors in most 35mm SLR's is spring loaded with a release from the rewind knob. Chances are your spring has lost tension, slipped out of place, or the teeth that grab the door have been damaged. You can always use the handyman's secret weapon (duct tape) to fix the problem, but if you're looking for a more permanent and less gooey and unattractive solution you're going to need to find a shop.
If there aren't any locally, you can find some online, or google KEH Camera if you're not sure who online is reputable. It'll run you $35 for a repair estimate which is waived if you decide to have the work done. Keep in mind some parts, for some cameras, are hard or impossible to come by so your model may or may not be able to be repaired, or may be priced outside of what you're willing to pay to have repaired.
Posted on Sep 09, 2011
