How does it work/seal? the bag is open on the right.
First you have to make a bag, so pull from the roll to the size you need, you might want to practice with a small one the first time.
Press the lid gently and the heat light should come on, when it turns green open the lid and you will have sealed one edge of the bag. (usually red means it is heating and green means it is finished)
To seal, place the bag over the vacuum nozzle to remove the air, usually pressing one corner starts the vacuum. When as much air is gone as you want, gently press the center of the lid again, and when the light is no longer red your bag should have the air gone and the bag sealed. DO NOT press too strongly on the center as that will cause the heated wire to cut the bag.
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
SOURCE: Looking for Manual for Rival Gourmet Seal a meal Vacuum food sealer VS110 B
http://www.sealameal.com/manuals/MANUALS/VS107_43_26445081.PDF
