The watches small second hand has come loose from its position and i would like to refit it myself but i cannot get into face, can`t remove crystal at front or movement from rear as i am unable to remove movement, i do have the back cover of its the stems i am unable to loosen out. please if anyone knows how to i would be very pleased to hear from you
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
SOURCE: Pulsar battery replacement
There is either a little lip around the edge of the back plate, or there is 5 notches around the back plate, If a lip use a sharp knife and put in the notch and twist upward, the back should either come off or move in that derection. Now if you cant see a lip, use a razor blade and in betwen the casing and the back plate insert the razor and with a hammer tap LIGHTLY it should come off or move in that derection, and then use a knife to pry off, If it has the notches, use a needle nose pliers and put in the two notches that are farthest apart and turn counter-clockwise. If you are still having problems please let me kno. I will be glad to assist you further. Good Luck!!
SOURCE: how do i set the alarm on my pulsar chronograph
http://www.pulsarwatches.com.au/files/instructions/137_1.pdf
SOURCE: I need an instruction guide for a Pulsar N945-6A20
Go to pulsar website look under manuals and select PWF series
SOURCE: lost stem on watch. can i get replacement? can i
mcdevito75 Here, Pulsar a quartz watch. If you lost the stem, the mechanism holding it into the watch maybe damaged, this mechanism also turns your Pulsar watch on / off. Best Bet, visit a small watch repair shop in your area, have them take a look at your Pulsar watch. You could replace the stem yourself but first you"d need the right size stem, (hard to get) then if the mechanism holding the stem in is damaged you"ve wasted your time. Your local small watch repair shop can let you know, and they usually don"t charge to have a look.
