AR-5516
SOURCE: H2 problem sharp AR 5516
H2 00 Content Thermister open Fusing unit not installed Detail Thermister is open (more than 4.6-V input voltage is detected). Fusing unit not installed Cause Thermister defective Control PWB defective Improper connection of fusing connector AC power supply defective Fusing unit not installed Check and remedy Check harness and connector between thermister and control PWB. Clear the display of self-diagnostics with SIM14.
Testimonial: "great"
SOURCE: sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Testimonial: "thanks a lot it was very helpful"
SOURCE: h5 erreur sharp AR-5516
if there is a paper jam in the fixing many times this err will be displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 and then start button.
