Earthway Ev - N - Spred Model 2050p Estate Spreader Logo
Shawn Wilkins Posted on Mar 04, 2012
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
Madison Corley
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 16 Answers
  • Posted on Jul 14, 2017
Madison Corley
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
16
Questions
0
Helped
20946
Points
63
To find the spreader setting, take the application rate of this product, which is 3.4lb per 1000 sq ft, and multiply it by .97. you get 3.38, which can somewhat be approximated on the spreader. The .97 rule can be applied to any lb/1000 ft sq application.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2830
Points
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
I have weeds in a circle form, in st Augustine grassl
Sounds like you have fairy rings. Yes, that's really what they are called! You can find out more here: https://www.planetnatural.com/pest-problem-solver/lawn-pests/fairy-rings/
They are frequently caused by the remains of a tree that formerly occupied that spot. There may have been remnants of the trunk left under the soil, and various fungi may now occupy the space.
Apr 24, 2017 • Garden
Setting for Bayer southern 3-1 weed and feed ?
Hi Mike:
Just an idea....
Check on the package and see if it gives you the settings.
If not, check with the store where you purchased the product and see if they have a guide /instructions available.
Cheers
4helpful
5answers
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 • Garden
12helpful
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
1helpful
I have an EZ Spreader by Republic pull behind for my lawn tractor and need to know what setting I need to use for applying Scotts weed & feed along with other applications. Where or how do I get this...
Go to this web page to get all settings......
Once there I would save the file and print it out for future use....
http://www.scotts.ca/media/media/pdf/spreader_settings.pdf
Sep 19, 2009 • Garden
6helpful
Repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Sep 06, 2009 • Garden
Top Earthway Garden Experts
Jay Finke
Jay Finke
john h
Are you an Earthway Garden Expert? Answer questions, earn points and help others
