Question about MTX Car Audio & Video
2002 Dodge Ram radio (not infinity) shuts off after being on for 6-7 seconds.
Previous owner said same thing happened with his other 2500 Ram and it was a later model. Playing a CD will give the same result- 6-7 seconds of sound then shuts off and shows the clock. If its turned off then turned back on (with car still running) you get another 6-7 seconds of sound before it again shuts off. We have someone on radio watch continually turning off and back on adn we then get to hear most of the song...;).
Posted by app_3rp12932 on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Infinity Bass link keeps cutting out.
Tapping into front or rear gets high level signal 3 plus volts at low impedance which is totally unsuitable for the sub's line level input which is more like 300millivolts > A competent tech could make up an attenuator patch or just take it to a professional car installer before you do more damage
ataraxia
Posted on Jan 16, 2009
Anonymous
  • 15 Answers
SOURCE: can't get it out of demo mode; radio/cd changer won't come on. reads only welcome to sony and shows clock.
try holding down the mode or power button... another menu should pop up... also refer to manual
Posted on Jun 17, 2009
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: Model KDC-MP142/CR
Hello swanaprslc,
It sounds like the "always hot" or battery wire is not connected to a 12V constant source. If you used a wiring harness, check and make sure that the pin in the harness that connects to the "yellow" wire coming from your Kenwood MP142 is hot with the ignition off. If you did not use a wiring harness, make sure that the yellow wire is connected to a fused 12V + constant source.
Hope this helps.
Posted on Oct 17, 2009
Anonymous
  • 5 Answers
SOURCE: dodge ram 2500 with factory trailer harness/plug.
check wire from beginning of the run
Posted on Sep 30, 2010
Anonymous
  • 62 Answers
SOURCE: Hi Can you please help
i would look for a little hole about the size of a pen nib. it would be the reset button. if that does not work then i would disconnect your cars battery and then remove your radio fuse for roughly 5-10 min ( to allow any residual currant to drain) then refit both. that should reset your radio system. It is EXTREAMLY rare for serious damage to be done to a car radio just from pushing buttons.
I hope i have managed to help you with your problem.
cheers
Posted on Jan 11, 2011
08 dodge 2500 radio wireing diagram
Go to this link and click on your make, model etc. If stereo not there for your year, go to year after or previous year and quite often are the same. http://www.the12volt.com/installbay/vehicles.html
Oct 19, 2014 | 2008 Dodge Ram 2500
2007 Dodge Ram 2500 Manual Transmission Trouble
Take it back
Did you not test it out--- before paying
& driving off?
Maybe the trans has some internal wear,
from the previous owners habits
Dec 08, 2012 | 2007 Dodge Ram 2500
Infinity wiring diagram
Robbie,
Sorry, your question is impossible to answer. First it is listed as 2004 Dode Ram 2500. Then you ask for a wiring diagram for Infinity. Infinity what??? What year? What model? Which SYSTEM for this Infinity are you needing wiring diagrams for?
Dec 25, 2011 | 2004 Dodge Ram 2500
I have a 1997 Dodge Ram 2500 4x4 Diesle 5 speed manual I have a factory radio with 6 disc. changer the radio works and so does the cd changer but I get very little volume Im sure its a amplifer problem....
To determine how your speakers are amplified you will need to know what speaker package is installed.
Usually Laramie editions come with Infinity speakers.
If I remember correctly the Infinity speakers have appliers on them.
My dodge truck is a year 99 2500 series, and I have already had to replace the door speakers. I used the cheap Walmart speakers. (6x9) They fit well enough.
Note: If your truck came with amplified speakers, non amplified speakers will only push what your radio can provide it in Wattage.
May 02, 2011 | 1997 Dodge Ram
2001 dodge ram 2500 (gasoline)
it sounds like the fuel pump to me also. when you first start the truck the fuel pump builds pressure in the system and as you drive the fuel pump can not keep up with the demand of driving. you should find a service station that can test the pressure that the pump is putting out to make sure
Sep 03, 2009 | 2001 Dodge Ram 2500 Truck
2002 Ram Radio problem
It sounds like a cold soldered joint internally in the radio. My advice is to buy a nice aftermarket radio with an MP3 CD player. MP3 gives you the option to burn music from your computer. In addition, MP3 CDs will hold over 100 songs per CD.
It MIGHT be a poor connection at the power connector on the rear of the radio. You could try pulling out the radio and cleaning the connection before purchasing a new radio.
Aug 08, 2008 | 2002 Dodge Ram Maxi
Car Audio & Video Logo
66 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Rob Beech
Rick Wrieden
Rick Wrieden
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
