Texas Instruments TI-30XA Calculator Logo
Jennifer G Posted on Mar 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How is this the answer?
1096.875 divided by 1 minus (1.00625)-360 (the -360) is an exponent. The answer is 1227. I can't figure out how to get this answer. I have tried everything and wasted too much time! Please help!! (I need to figure out how the book is getting this answer because I have 17 more problems to do!)
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Mar 04, 2012
k24674
Level 3:
Answers
8093
Questions
0
Helped
4674930
Points
21596
Start with the more complicated part. Use parentheses to make sure the correct argument is entered.
1-1.00625^(-360)= the result is stored in ANS memory
Then use 2nd Ans [x:times] 1096.875 = 1227.121463
For the minus sign in front of 360, use the change sign (negate) key marked (-) or (+/-)
2 Related Answers
Anonymous
  • Posted on Feb 08, 2009
SOURCE: dividing by a negative exponent
(2x3^2) divided by (2x3^(-2))
just make sure to use double parenthesis around the negative exponent so that you get the right answer
Anonymous
  • Posted on Mar 05, 2009
SOURCE: exponent key
On the Upper right corner, below the OFF button.
Key in the number, press that YtotheX key, and input the integer. Press =. That is your answer.
Hai again your support helps me alot can you please differentiate for me between the following -6to the power 2 and -6 to the power 2,& 2 to the power -3 + 1/3 to the power-2
Fixya maths 4 indices
Indices n surds
I need a clarity how to convert these exponents to fractions
Posted by Ncwana Noziphiwo on Apr 03, 2018
https://www.tes.com/teaching-resource/indices-negative-indices-6427219
-62 means a number multiplied by itself twice
So in this case it is -6 x -6 = 36 - since -x- = +
If this was -6-2 the negative power means it's a fractional indice so first make it look like a fraction
1/-62 now it looks like a fraction (inverse) and the power mow looks like a normal square
Coz its still a negative number -6 x -6 = 36
So the answer is now 1/36
So when it is a minus power, first turn it into a fraction, then calculate as normal
Note: every number has a sign, it is either + or minus.
By convention, we always assume it is a plus unless stated otherwise.
To make sure u remember this fact put a plus sign in front of every number if no sign is showing
You can start with buses the 27 bus is +27
Its like if u say u have a car, what u really mean is you have 1 car. But u drop the 1 coz everyone takes for granted u meant 1 car, 1 house, 1 friend etc
Every power we assume its + unless otherwise stated.
So when a minus is put in front of the power, its saying make it a fraction first!
Maths is a game and games have rules.
This rule is a minus in front of power (indice) change to fraction form first!
So if it is 2-3 - the power -3 is saying turn it into a fraction first so
1/23 = 1/ 2x2x2 = 1/8
If it had of been 23 notice how no signs shown because we take for granted they r all +
Let's show them
+2+3 since it's a plus 3 we don't need to change it to a fraction and since it is a plus 2
We have +2 x + 2 x +2 and a +x+ x+ = +
2x2x2 = 8
Its easier to just do 23 = multiply the 2 by itself 3 times
2x2x2 = 8
When doing fractions of any type I prefer showing them as being more obviously top/bottom
Format and for that free hand is easier as typing is hard...lol
Ie
Numerator Denominator
When using a number that's a fraction it is better tro enclose it in brackets
As every indice is of the form - numberpower
The number can just as easily be a fractional number like a 1/3
So (1/3)2 is a third multiplied by itself
1/3 x 1/3 = 1x1/3x3 = 1/9
If it was (1/3)-2 then first u must get rid of the minus power by turning it into a fraction
1/(1/3)2
1/1/3 x 1/3
1/1/9
And 1 divided by a ninth =
1 to be cont - tired..lol
Apr 03, 2018 • Homework
Dividing 2 different scientic equations into another
Sorry but you are using the word EQUATION incorrectly. All you have is two numbers you want to divide one by the other.
Enter the numerator 1EE (-) 14, press the division key / then enter the 5 EE (-) 12. Press the = sign.
Note: to enter the negative sign in the exponents, use the change sign key marked (-), (+/-) or [+/-] . Do not use the regular MINUS sign.
When you use the EE key, you must not enter the 10. It is understood because EE is a shortcut for *10^.
I am trying to add/subtract & multi/divide with a TI 30XS. I can't close the parenthesis. I'll enter the number, then x10n, the exponent, but when I try to close the parenthesis it display
Are you opening the parentheses in the first place? If you don't have a left parenthesis then you don't need a right parenthesis.
Could you post the exact sequence of keystrokes you're using?
3helpful
I dont understand why I keep getting the wrong exponet in trying to figure out 1500nm divided by 10^9. the answer I get is 1.5 *10^-7 -but the answer is 1.5*10^-6. What am I doing wrong?
Without knowing exactly what you're doing I can't be sure, but I suspect you're entering the 10^9 as something like 1 0 EE 9 .
1 0 EE 9 gives you 10 * 10^9, which is 10^10. You should be doing this as 1 5 0 0 / 1 EE 9 = .
1helpful
Just got a SHARP EL-531X, it won't do simple calculations with scientific notation, It keep saying
To enter the power of 10 with exponent use the Exp key followed by the exponent. If the exponent is negative, you must use the negation key (-) not the - key (for subtraction).
When you press the Exp key you do not type in the 10.
Hi, how do i use casio fx82ms to raise a figure eg. to the power of 4?There's no xto the power of y button....
There should be key marked [Y to the x] or [^]. If exponent is negative use the change sign key (-) not the MINUS sign.You will have to use the [^] key if you calculate roots of order higher than 3. Example 7th root of 353 =(353)[^](1/7)
1helpful
What is the answer to 10x minus 3x equals 20 plus 1 equals what
joshua,
X = 3 (answer)
Here are the solution steps:
10X minus 3X is 7X (right?)
20 plus 1 is 21 (right?)
therefore:
7X = 21
now divide both sides of the equals sign by 7
7X divided by 7 equals 21 divided by 7
7X / 7 = 21/7
X = 3 (answer)
More math? Ask for Gort007
Thanks for trusting FixYa !
1helpful
Dividing by a negative exponent
3answers
Formulas
meri excel file ka security paasward missing. Pls i want track the paasward.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
