SOURCE: 36 inch toshiba Tube tv manifactured in 1997
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
SOURCE: picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
SOURCE: basic cable scrambled on ANT input but not PIP
it sounds like you have the common problem with these models. The poblem has occured so offten that toshiba issued a service bulliteen about it. There is a problem with a cuircit board called the Hypermodule its a signal processing board/ the ideal situation would be replaced this board but it has happen so much it may be difficult to find this ooard so this board can be repaird. The secound problem is to fix this board 11 very very small parts called capacitors need to be replaced. i have also replace these and only someone advance in solder should attempt it very small. twezers and magnifer. You can hire someone but it very labor intensive. Our shop charges 300 just in labor It can be fixed but I would adviise its just no worth it
SOURCE: I bought a toshiba 36HF12 36" tv
The TV does need a converter box to receive digital off-the-air broadcasts. It's an HD set, but that doesn't mean digital; no digital tuner was built in. You can find the manual here at Toshiba. Hope this helps, and thanks for using Fixya!
