I bought used Turbochef Tornado, and there's some problems: The door fails selftest. It can't be adjusted, because the doors opposite surface isn't straight. It takes contact at the lower part at all the way, but at the higher part it makes contact only at corners. So the sides and center part of higher part isn't tight. What to do, du i have to grind it to straight, or use some kind of seal or what? Second problem is the magnetor blower. It wont stop before I take the plug out of socket. When I put socket back, the blower is stopped, and starts then when it's needed to. But it never stops by it own. What to do?
First aligning the doors on these ovens are a pain. In the service manual there is a whole chapter on doing this process. Contact turbochef and buy a manual for 30 bucks.
Second the mag fan should operate for 4 mins after the cook cycle has completed to continue cooling the mags down. If it goes longer than this then the control board chip needs updating or you have a bad mag fan relay.
SOURCE: turbochef tornado
This oven has 2 mags in it this error codes explains that one of these are failing.
SOURCE: F3 Mag Curr. on Turbochef Tornado
Hello. Interesting coincidence, but that error code is for the magnetron/microwave part of the toaster. You will need to have it serviced by someone familiar with the unit, it could be easy and reasonable, if just a fuse blew, but not likely. If the fuse blew, it is 20amps, so something took it out. Call turbo chef, they will get you to the closest servicer, may be able to help you on the phone.
Here:http://www.turbochef.com/commercial/site.php?PAGE_TYPE=CONTACT
or 1800 90turbo
Hope that helps, and thank you.
SOURCE: I have NGC tornado Turbochef, it is toasting too
temp should only be no higher than 500 try that
SOURCE: Problems with TurboChef TORNADO Electric Oven f8
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
SOURCE: My turbochef tornado gives an error messag of
Could be the speed control PCB, or the motor, You need to test the impedence of the motor. You may have to replace both the motor and the PCB.
By the way, how does the oven recognise if the door isn't tight? Is there somekind sensor of airpressure or what?
The oven does not have any kind of air pressure or anything like that. The door switches are simply out of alignment. That is the only way this oven know what the door is doing. It has 3 switches that are quite sensitive.
