Televison & Video Logo
Anonymous Posted on Dec 08, 2017
How can I program a Philips SRU8010 universal remote to work with Viera Link on my Panasonic TH-L37U20M lcd?
I have bought a Panasonic used lcd with no remote, and the mentioned above universal remote, but when i program it to my lcd, the important buttons such as the Viera Tools doesn't work. is there any way ro program the universal remote to do those actions? or must i buy the tv's original remote? thanks.
5 Related Answers
Anonymous
  • Posted on Apr 27, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
A
Anonymous
  • Posted on May 06, 2008
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
Anonymous
  • Posted on Jun 16, 2009
SOURCE: trying to find comcast digital code to use their
10250
Anonymous
  • Posted on Oct 03, 2009
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Anonymous
  • 178 Answers
  • Posted on May 20, 2010
SOURCE: Panasonic Viera TH-50PX60U Plasma is stuck on one
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
Testimonial: "Thanks TV Help-Dave! Your solution was right on the money. Speaking of money....This site just saved me a $79 service fee. Great idea for a website!!"
2answers
I can't set up my tv panasonic viera TH-37LZ85 because it's in chaina language and I don't have a remote
please use Amazon or ebay to acquire a compatible remote so that you can move forward with updating the device language. You might also call local stores that offer device rentals to request a temporary rental or use of the camera remote.
Thank you.
Nov 10, 2022 • Cameras
TH-P50V20A panasonic Viera remote codes
have you tried all these with the remote?
13833 18250 14039 15716 19503 12362 14333 12055 15532 15355 19617 15659 10508 16940 17845 12001 10916 14912 16513 18310 18810 11520 17127 17731 18649 18029 14852
How to connect viera link
What is Viera Link? Viera Link allows the control of other Panasonic home AV devices via the television remote control.
By pressing the Viera Link button on the television remote, it is possible to turn on and navigate the menus of other Viera Link equipment. Please note, Viera Link requires an HDMI connection between the television and the external source.
More control functions have been added with each new generation of Viera Link compatible products. However, it is important to note that the newer functions only work if both products are from the same year of manufacture. Therefore, if an older source is used with a newer year of television, only the older functions common to both years will work.
3helpful
My original remote for Panasonic Viera no longer works. I have bouht a universal remote but do not know the panasonic code to put into it. please help
each brand unversal will have its own seperate code for panasonics. I would recommemd getting the original remote which wont require any programming. You can get the remote from www.tvrepairworld.com
Need User Manual for Panasonic Viera TH-L37X10S Lcd tv
The manual for theTH-L37X10S is available from Panasonic here: http://www.panasonic.ae/EN/Manuals/TH-L37X10A.pdf . (Note it's the same manual even though the final letter is different.) If the above link doesn't work, start here: http://www.panasonic.ae/EN/Pages/TH-L37X10.aspx and click on the Manuals tab.
I hope this helps.
I HAVE A PHILCO URC2070 & NEED THE CODES FOR A PANASONIC TV
Codes for PANASONIC: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
1helpful
When your power button is broke, can you still program a universal remote?
yes but universals will not program for all sets and will always miss some key features you need.
Most universals have a search mode where you (even with set off) program and try each--one at a time until set comes on.
If you have the original remote and it does not work--it can be tested and in most cases fixed.
1helpful
I have a panasonic tv and bought a phillips universal remote and lost the code book, how can I program remote?
Here's the link sir for you to program your PANASONIC T.V on your PHILIPS UNIVERSAL REMOTE CONTROL..
I need a remote for panasonic lcd tv
Hello
Buy one "Atlas Metrocast OCAP-5 device" universal remote contro. Most of the present devices are listed with its codes. Codes for Panasonic are:
0250, 0051, 0055, 0162, 0226,
0338, 0375, 0650, 1291, 1410,
1941, 1946, 1947
You will get its catelogue with it, describes all the setup proceedings. OK.
1helpful
Sens 23" LCD tv cd combo
Good news - it's under warranty. Take a look at:
http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/Warranty-CCP/model.TH-50PZ80U.W#ts
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
