Question about Brother HL-5240 Laser Printer
How do I change the drum in my HL-5240
How do I change the drum in it myself?
Posted by Annie on
Nihamdeen
    New Friend:
    Problem Solver:
  • 10 Answers
First check whether it is possible to buy a new drum for your model, if possible buy a new drum then remove the toner from your printer, separate the drum unit from the toner, if you check thoroughly the left and right sides of the drum unit how the drum has been fixed in to it you will be able to find the way remove drum from the unit, then replace the new drum and fix it. Don not tough the edge wiper blade, rotate the drum and check whether it rotating smoothly in both direction.
Posted on Apr 23, 2012
5 Related Answers
Everett Lin
  • 990 Answers
SOURCE: Brother HL 5240 printer: Drum light flashing
you need to replace drum cartridge, when you buy one back ,look new one then you'll find out where is the drum.
Posted on Dec 16, 2008
Anonymous
SOURCE: The drum light came on
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Posted on Jan 21, 2009
Anonymous
  • 41 Answers
SOURCE: HL-5240 is printing a big black line down the page
CHANGE THE DRUM UNIT.iT IS THE UNIT THAT THE TONER CLIPS INTO.
Posted on Jun 26, 2009
Anonymous
  • 81 Answers
SOURCE: need to clean my 5240 brother laser printer drum
Chances are if your drum requires cleaning, it could be faulty or at the end of its life. However if you must clean it DO NOT use any cleaning agents , chemicals or water. Use only the softest lint free cloth you can find and give it a gentle wipe over
Posted on Aug 22, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: How do you replace the drum properly on a Brother
Out with the old and in with the new, you remove the toner and drum together, remove the toner from the old drum by pressing the blue lever on the side, install the toner in the new drum, and re install in the printer. With the front door open press the go button til all lights flash and then close the door, the new drum is reset.
Posted on Nov 20, 2009
Why is my paper curling in my HL 5240. Does it have to do with me putting in a new (non refurb) Drum?
Paper curling is usually due to paper that has absorbed too much moisture. Try a new **** of paper that is sealed and I would bet that the problem will disappear.
Mar 13, 2011 | Brother HL-5240 Laser Printer
Changed out drum and now need to reset the counter on HL-5240. How is this done?
Drum reset procedure on this model is quite simple. Just open front door, hold down the GO button until all lights are on, let go of button then close door. This will reset drum counter to 100%.
Thank You for using Fixya
WheatlandServices
Dec 23, 2010 | Brother HL-5240 Laser Printer
How do you replace the drum properly on a Brother HL-5240
Nov 20, 2009 | Brother HL-5240 Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
Brother printer prints solid black on one side
This is caused by a faulty drum/charging circuit or laser unit. The drum is positively charged with static electricity and a laser draws the image onto the drum (changing the charge to negative) the toner is positively charged to it will adhere to the negatively charged image which is now on the drum. your problem is that the drum is either not being positively charged or the laser is charging the whole drum. There is a corona wire on the drum, remove the drum, sweep the corona wire (there will be a tab that moves left and right) and try it again. next step is to replace the drum. if you dont have a spare drum or one from another printer then it may be more cost effective to buy another printer as drums are quite expensive and it may not even be the problem.
Jun 16, 2009 | Brother HL-5240 Laser Printer
Dec 16, 2008 | Brother HL-5240 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
May 30, 2008 | Brother HL-5240 Laser Printer
Brother HL-5240 Laser Printer Logo
150 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
