Hello Check the cooling fans at the top working well or not. If found damaged, replace it. It is normal that a plasma TV will heat up to an extent. If it overheats, cooling fans should be suspected.
Hi, If they get hot you have put them in wrong. Put + to + and - to -
This should turn on the device. Be careful some batteries can explode when they get too hot.
there are 2 heater core **** at the back of the motor .are they hot .you have to let it run to see if they gety hot . they get hot then you have a bad or stuck blend door motor
AT boot the screen doesn't come on? If it's hot, remove all media, CD's DVD's USB, etc, turn it off , unplug, remove battery, let it cool off and replace battery, plug in, reboot. Is there any change?
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses. Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Hi, I would turn the power off first for 5 minutes and then back on again, this normally works for me.
You can also check on the front screen of the unit that it is in "Normal Operation"
Cheers
Pete
my mp3 player screen went black, it is getting hot on the inside, and when i press the power button and press it to play, i get a repeating noise. computer will not recognize it. and screen stays black, what is wrong
I had the same problem - has been acting up since new but is off warranty. I took it apart and found the oscillator crystal was hotglued onto one of the LSI chips and was being squeased by the case. I moved it down between the chips and reassembled - has been running close to 8 hours now without failing. Used to lock up with the line after about half an hour.on't know for SURE if it is fixed, but it appears to be at this point.
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
