Question about Kohler Plumbing
Kohler tub faucet valve seat
I rounded out the cold valve seat trying to get it out. Should I just drill and re tap the hole in the valve housing? I was told by a friend to just grind the face flat, which I don't think was right, If I tap new threads and teflon tape the new seat thread will it fix this $5 problem that got bad quick?
Paul Carew
  • Kohler Master
  • 3,530 Answers
You can cut a new seat first which is good in most cases . I would not do what you are saying you are going to make your self problems . Reseat if it don't work get a new tap.
Posted on Dec 30, 2017
5 Related Answers
Anonymous
  • 171 Answers
SOURCE: rohl 3810 faucet nut not engaging threads
Hi murphygm,
I'm Harvey the Master Plumber.
Your problem is: You have replaced a leaking Rohl cartridge in your kitchen faucet, but when you
replace the nut holding down the cartridge, the threads of the nut do not
engage. You have tried to push hard down on the cartridge while you turn the nut,
but to no avail.
Assuming you have the correct cartridge, I find it helpfull to take pictures with my cell (easily deleted later) as I disassemble to make sure I'm getting the new one in exactly right because there are only two reasons why the new cartridge won't go all the way in. 1 It's the wrong cartridge or
2 something's not right. Take the new one out and check that everything is correct, it's easy to make a small mistake. That's it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Posted on Feb 08, 2009
bwbconstruct
  • 23 Answers
SOURCE: Leaking valves in new roman tub faucet installation
take the valves out and check the valve seats use flashlight if they look good then very carefully put your finger in and feel for any burrs when in doubt just replace the seats this is always a good practice when replacing valves
Posted on May 12, 2009
woobie dog
woobie dog
  • 1273 Answers
SOURCE: i have all 3 new shower valves purchased from home
Most Price Phister valve cartridges have a plastic washer or "O" ring at the base of the cartridge, where it screws into the valve body. Replacements should be available at H/Depot, Lowe's/similar.
Regards, --W/D--
Posted on Jul 21, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
Oct 05, 2016 | Kohler Plumbing
Just lost pressure. Only a very small stream of water comes out, hot or cold. All other faucet in the house work fine. It is about 1 1/2 years old. R10433-CP
First try the tip ariator. it can plug up. then you have to check the inlet system, which includes shut off valves, hoses to the faucet and the cartridge. It is the cartridge that has the small openings, but shut off valve seat material falls back into the feed channel. I usually remove cartridge, cover with a towel and turn on feed water briefly. Often I get little pieces.
Oct 27, 2010 | Kohler Model 10433: Fort® Single-control...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the...
If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
Caution- this procedure can get messy, close the shower curtain or door.
Call Kohler and ask for a new mixing valve for free.
Sep 12, 2010 | Kohler Plumbing
How to install the plumbing of a moen shower tap
the big round black plastic is part of the installation it will screw to the valve body thats the size of hole the black round cover is also backing plate to round external dress cover so be careful not much leway when cutting the center part should be knocked off but keep on to protect chrome escutcheon take off when applying handle also remember unit is shipped in cold position need to adjust hot water shipped in cold position because of anti-scald system
Jan 22, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Mar 26, 2009 | Plumbing
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
Feb 08, 2009 | American Standard Plumbing
Plumbing Logo
77 people viewed this question
Top Kohler Plumbing Experts
Mike
Bill Johnson
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
