Question about Sanyo DVW-5000 DVD Player/VCR
What type of disks does the Sanyo DVW-5000 play?
I have a dvd-rw with an .avi movie file I am trying to play on my Sanyo DVW-5000 and it tells me that there is an disk error when it tries to load the disk. What type of disk/file types does this dvd player play? I want to be able to play the dvd that I made and I am not seeming to be able to.
Please help!
Thank you.
Kat Morris
  • Arlene Hill Dec 12, 2008
    Does DVW5000 use dvd-r or dvd+r
    Master:
  • Sanyo Master
  • 434 Answers
6ya staff
SOURCE:
petraman7
Scott Frye
  • 1175 Answers
SOURCE: How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Posted on Feb 24, 2008
Anonymous
  • 3 Answers
SOURCE: owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Posted on Mar 21, 2008
Anonymous
  • 3 Answers
SOURCE: Looking for code
Try 0243 or 0328
Anonymous
  • 232 Answers
SOURCE: How to Hook Up Sanyo DVW 5000
TRY A DIFFERENT TYPE OF VIDEO OUTPUTS LIKE S-VIDEO, OR COXIAL
Posted on Aug 05, 2008
marked
Mark Gil
  • 6487 Answers
SOURCE: Sanyo DVW 5000 VCR-DVD player-recorder
Sorry for the inconvenience you encounter,, But for your concern since you encounter a power surge sometimes some electronic/electric device like might git damage because of the power flactuation, probably some of its IC,s got burn if you want you take it to a repair center and hopefully they will just replace the burn IC's ..
Hope that helps......
Posted on Aug 06, 2008
Sanyo 500 tries to load dvd but won't play dvd
Does that specific DVD work in some other DVD player?
Does that specific DVD work in the DVD-drive in your computer?
Dirty disk?
Feb 15, 2014 | Sanyo DVW-5000 DVD Player/VCR
My VCR plays great but the DVD won't load the disk. I have changed disk types and manufacturers. Nothing has helped. Do I have to connect the AVI cables for the DVD to work?
the reason is because your dvd player inside got caught on something in side and now won't work for your disc it might even be off track...
Sep 09, 2010 | Sanyo DVW-5000 DVD Player/VCR
When i try to play movies the player say unable to read disc. what type of disc should i use to make my movies on or what movie format should i use.i have a sanyo dvd player.
http://www.retrevo.com/pdf/308ci475/3/Playable+Discs#q=Sanyo+DVW-7000
visit this site for the req. information,also to download the manual
May 23, 2010 | Sanyo DVW-7000 DVD Player/VCR
Will the dvw-5000 play the dvd-ram disc ?
By looking into your information, I found my answer. " What disc will it play".
Aug 07, 2008 | Sanyo DVW-5000 DVD Player/VCR
Jul 21, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sanyo dvd/vcr dvw 7000
I have a Sanyo Dvd/vhs player and I recentlty went to dish network instead of cable and I do not know how to get the player to work now so I can watch movies that I have rented. Can you tell me how to use the remote to watch movies.
Apr 08, 2008 | Sanyo DVW-7000 DVD Player/VCR
LG RH188H - what movie file types does it play?
AVI are a certain type of movie file.
Your problem is most likely that you do not, have the correct software ( program ) installed on your computer to view these files, yet i believe do play on a normal DVD Player.
you could try Windows Media player, this may work for you. also power DVD or Similar. although there are newer programs out there. as for the conversion, this is a long winded process in itself. To convert AVI To MPEG ( standard DVD Format ) you need unpacking tools and software, And a relatively high spec PC, Lots Of Memory.
Hope this guides you.
Mike @ compurepair.
Feb 29, 2008 | Televison & Video
Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
Apr 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Sansui VRDVD4000 format
I do not believe this player plays AVI videos, not to mention whatever codec you are trying to use.
Download VSO ConvertXtoDVD and convert your AVI files to DVD and then burn them to DVD-R (NOT DVD+R), the 4.7GB discs (single-layer).
This process takes a very long time, depending on the size of the movies you are converting, some 1-2 hours, some 8-24 hours.
I suggest buying a Philips DVD Player that plays DivX and XviD AVI files, they seem to be the best. You can just burn the AVI to any disc and it will play. [Most popular seems to be Philips DVP 642]
Cheers.
Jan 08, 2007 | Sansui VRDVD4000 DVD Player/VCR
Sanyo DVW-5000 DVD Player/VCR Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
