SOURCE: i forgot my nokia N79 lock code, someone please help.
pls go to service center if in warrenty...or reinstall the software of phone from nokia.com
SOURCE: i want to reset my Nokia E63 factory setting.. for...
When phone is off try using this key combo: on/off + * + 3
SOURCE: master code of nokia 5610d-1 Problem i want to
can you tell me security code to reset nokia sn:358652019222666
SOURCE: I need the factory master
other way is ....... *switch off your phone
*press *3&call button constantly.
*switch on your phone
*switch on it, your problem will be alright......
Hi, I think it may Helpful to you
Try to format the phone memory, but this will erase all your data, so, first save the info you need- contacts, photo, etc.
1) Factory defaults-
Type *#7780# on your standby screen.
This will reset all your setting to default factory settings. User data wont be affected. (Default Lock code is 12345)
2) Soft reset-
Type *#7370#
This will reset the phone as well delete user data. Use when want to format the phone.
There is a rate option "Was this helpful?" Yes or No.
If you are helped you can rate, that is your choice
