Hey guys ..i use my laptop a lot as all my work is done on it .... since past 6 months my laptop is overheating on the left side.,. and some times the cooling fan also stops . it heats up so much that i cant even touch it ....and then it goes in sleep mode...even after pressing fn it comes out and again goes in sleep mode....guyss what shud i do ??
Many laptops accumulate dust inside the fan/heat exchanger assembly over several months or years, and must be removed in order for the laptop to properly cool itself. Depending on how much you use the laptop, it can happen in as little as a matter of months. You may want to ask a laptop repair place how much just to clean out the dust, and see if that works. Sometimes a cooling pad can help, especially if the laptop isn't already on a hard, flat surface.I actually keep my laptop on a small wooden board the same length & width as the laptop with a cooling pad on top of that, and the laptop on top of that, because I often want to set my laptop on my bed, which can smother the air circulation, and cause it to overheat quickly otherwise. Even when on a hard, flat surface, like a table or desk, if I am playing a game, I put it on the cooling pad because games cause the laptop components to generate a lot of heat, and this brand is somewhat notorious for overheating (especially when it has a discreet graphics card).
Testimonial: "thanks a lot ...really appreciate your help :) "
