Sounds like you either have a bad memory module or else it isn't properly seated in the memory slot properly.Access to memory slots in laptops can be as easy as taking off a panel, or as difficult as taking ff the keyboard. Sometimes, one slot us under a simple panel, and the other one is under the keyboard. If you are mechanically inclined, you may want to remove and reseat any memory you find under a panel on the bottom.There is a "how to" here that shows you how to remove and replace a memory module in a laptop:http://www.ehow.com/how_5468843_change-ram-laptop.html
Testimonial: "Thank you so much.I did removed the module,gently cleaned both the ram card and the slot where it was installed and then I put it back,i also drained the CMUS Battery. so that when I turned it on everything went back to normal and my laptop now is working good.You're a great help..."
SOURCE: Compaq Armada M700 Shut Off During Windows XP Pro boot
It's usually caused by the Voltage-Regulator sub-board that is faulty M700/M300 - same problem. If the VR sub-board is replaced and problem still exists, mobo is faulty.
SOURCE: unplugged my armada m700
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
SOURCE: compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
SOURCE: Compaq Armada M700, Dim Screen
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
SOURCE: installing wifi in Compaq Armada m700??
yes,
aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series
it's alot better
The product key came with your
documentation that you purchased as an addition to your PC.
http://office.microsoft.com/en-us/home-and-student/office-home-and-student-FX101845698.aspx
Thank You So Much.I'll Try to replace a new ram card or maybe try to change the HDD...
