Question about Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven
Smeg pyrolytic door lock - Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven
Posted by gbnewlynn on
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Smeg sca130p. Interlock wont release after running through pyrolytic cycle. Tried running through cycle again but still wont open hours after cycle completed.
Cut the power to it completely, so if its on a breaker, press the test button on that breaker. Wait 3 minutes and put power back on. Has it cleared the problem?
Dec 21, 2013 | Ovens
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Oven door is locked
its pyrolytic. if it hasnt finished embering the insides of your cooker (And usually meal) then the pyrolytic lock has failed (usually due to the pyrolytic 500* heat)
Feb 21, 2010 | Maytag Ovens
Lots of water/condensate ends up on bottom of oven
I have the same problem with my new Smeg oven. I try to avoid using the oven at the moment because of the amount of condensation I have to mop up each time I use it, even the floor get wet!. Smeg have said they will replace it but I am now looking for an oven that will fit into the 'whole' the oven will leave in my newly renovated kitchen. I wish I had never ventured near to SMEG. I would never recomend Smeg to friends, quite the opposite.
Jan 19, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Dec 28, 2007 | Electrolux EOC6690X Pyrolytic Electric...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Open Questions:
See all Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Questions
Smeg UK2010X-1 Pyrolytic Stainless Steel Electric Single Oven Logo
Top Smeg Ovens Experts
Paul Bade
Dennis Boxerman
Are you a Smeg Oven Expert? Answer questions, earn points and help others
