Pitney Bowes DI200 how to clean - Office Equipment & Supplies
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Service Manual
A good place to find one is on copytechnet.com. I checked some of the service manual websites and nothing was comming up with that model number. It could be because Pitney Bowes spun it off into Imagistics and now it's called Oce. Usually the copiers are made by Ricoh. Someone on there would know where to get the service manual under the Ricoh model number as well.
Posted on Jul 11, 2008
Anonymous
SOURCE: Pitney Bowes Copier - C180 - Error E3
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Posted on Sep 17, 2008
Anonymous
SOURCE: I am looking for a service manual for a Pitney Bowes FD40
http://www.pitneybowestsg.com/public/Opguides/Fd40u036.pdf
Posted on Mar 20, 2009
Anonymous
SOURCE: looking for a service/repair manual
At minimum, the drum and cleaning blade need replacing - possibly developer as well. I'm sure the optics are dirty, as well as the charge and transfer corona.
Posted on May 01, 2009
Nike Merritt
  • 149 Answers
SOURCE: Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Posted on Feb 24, 2010
Copiadora pitney bowes dl 200 error en dispey co500 lla puse tehrmistor y sigue igual como se resetea este codigo
The problems is in the fusing unit.Clean the thermistor and heater lamp.Reset the trouble:press the microswitch located in the right side to display pane,under the display contrast button.After appair the * simbol on the display,press 3 and the Trouble reset button.
Aug 07, 2010 | Konica Minolta DiALTA Di200 Copier
I am trying to find a fuser asm for a Pitney Bowes C550
Your Pitney Bowes C550 is made by Minolta, Model EP5000. Precisionroller.com is a good source for parts. Just do your searching by the Minolta EP5000 model and you find anything you need.
Good Luck and Thank You for using Fixya.
Jun 05, 2010 | Office Equipment & Supplies
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Pitney Bowes 8000, when I go to Copy it prints BLACK
your thermal print head is bad. This is a very old machine and I do not know where you can get parts. This machine is no longer supported by field repair
Aug 20, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes C420
The drum or the cleaning unit has gotten too worn. call 18002435556
Jan 07, 2009 | Pitney Bowes C180 Copier
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
289 people viewed this question
Marvin
Marvin
