Question about Proscan PS27123 TV
How to connect a dvd player to a proscan ps27123
How to connect a dvd player to this tv and view the picture because I have a new dvd vhs player recorder with only rca cables and I still can't get it to show a picture
Posted by J Rivera on
5 Related Answers
Anonymous
SOURCE: hooking up dvd player
You have wires hooked properly.
On your remote, hit input button, press down arrow once to AV then press right arrow button.
Then watch a DVD.
It worked for me.
Good Luck
Posted on Feb 02, 2008
Anonymous
  • 129 Answers
SOURCE: I have a proscan TV
Good day.
I believe the power supply circuit of your unit got busted. You can also try replacing the fuse. It might caused the problem.
chris
Posted on Mar 23, 2008
Anonymous
  • 813 Answers
SOURCE: DVD input failure
hi friend
can u plug ur cable correctly
in bhind or in front of your tv thats socats come so plug ur socact bhind the tv try to on ur dvd player
Posted on Apr 05, 2008
Anonymous
  • 129 Answers
SOURCE: Proscan PS27123 TV Problem
just to be sure, is it vertical or horizontal? Anyway, if it is vertical, it could point out to the vertical Ic section or some loose contacts along the lines. If it is horizontal, it could be a filter capacitor along the horizontal Circuitry. Mark the high voltage capacitors along the high voltage sections.
regards,
chris
Posted on Aug 16, 2008
Anonymous
SOURCE: PROSCAN PS35130
I got an old (1995) 36" proscan without a manual, and it's been a pain to get it working. Nice enough TV once you do, though.
The weirdest thing is that S-video shows on channel 91, and the AutoProgram function won't find it. That's right; they just randomly picked 91, and you're stuck with it.
Pressing Menu on the front brings up the menu. Pressing it again cycles through choices, and the plus and minus buttons to the left of it activate the choices.
Good luck finding any more info; hope this helps
Posted on Sep 11, 2008
PROSCAN PS27123 TV directions how to hook up dvd player
First, I strongly urge you to purchase a short HDMI cable IF BOTH units are equipped to utilize them. Run HDMI "out" from the player and hook the other end to HDMI "in" on the TV. That will avoid all this angst you are experiencing now since HDMI carries audio and video at a high resolution.
If you must use the RCA cables, make sure they are coming out of the"out" jacks on the player and going into the "in" jack on the TV. Now, I feel strongly your problem has to do with the "input" or "source" button on the remote. You MUST have it set to DVD player. Play with it. It's imperative to, with the remote, select the proper source - which in this case is DVD player, rather than, say, cable box, computer, etc. By the way, even if you use HDMI, you'll still have to do that, and you will also still have to select the correct input (sounds maybe like you have 3). Good luck!
Jul 26, 2017 | Televison & Video
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Lost remote control
Go to your local shop of electronic parts and ask if they have a remote control for your Proscan PS27123 TV. If they haven't, ask for universal remote control (or go to another shop). Of course it's the expensive way of the problem solution, but it's worth it.
Sep 08, 2008 | Proscan PS27123 TV
VHS side doesn't have pictures
the connection from your player to TV is only single output not separated DVD and VHS. If there is picture when used on DVD then you should be having problem with your VHS player. Question.... is your unit new? Is this the first time you encounter this problem? what is the brand of your player?
Jun 28, 2008 | Televison & Video
I have a proscan TV Model PS27123. We've had a lot of power outages in our area due to bad storms and the other TV sets came back on except thi one after we recovered power.
Good day.
chris
Mar 13, 2008 | Proscan PS27123 TV
Proscan tv ps27123
a capacitor blew up, or the flyback exploded?, happened to a RCA 27" tv i used to have!
Nov 22, 2007 | Proscan PS27123 TV
Televison & Video Logo
Top Proscan Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
