Canon EOS 3000 Kit 35mm SLR Camera Logo
Question about Canon EOS 3000 Kit 35mm SLR Camera
How do i fix error 99 on my camera
Posted by Abigail nesbitt on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Error 99 is Canon's catchall error, basically meaning "none of the above." The most common cause is miscommunication between the lens and the camera body. Take the lens off the camera and clean the electrical contacts, both on the back of the lens and in the mount on the body. Try a different lens if one is available.
Posted on Mar 02, 2012
I keep getting error 99 message
Error 99 is common error on Canon cameras. Make sure the battery is freshly charged. Take the battery out, the compact flash card out, and the attached lens off of the camera. Leave the camera set for a while for the capacitors to bleed off. Around a half hour would be good. Next re-insert the battery and push the shutter button as if you were taking a picture. If you get an Error 99 then, you can't fix the trouble and Canon will have to do it. If you do not get an error 99, power the camera off, insert the compact flash card, power the camera back on and press the shutter button again. If you get an Error 99, the trouble is in the compact flash card or its connector. Try a different card. If you do not get an Error 99, power the camera off, a lens on it, power the camera back up, then press the shutter button once again. If you do not see an Error 99, the problem is no longer in the camera. If you do see an Error 99, power the camera off and remove the lens. The problem is probably in the contacts on the camera or the lens. Clean the contacts by holding the camera carefully with the lens opening down so it will not allow dirt to get inside the camera. Take a cotton swab dipped in alcohol and clean the gold metal contacts well, Dry the contacts with a tissue. Next hold the lens with the contacts down and repeat the process on the contacts on the lens. Be very cautious not to allow lint, dust, or alcohol to get into the camera body or into the lens. Some people use a pencil eraser to clean the contacts but you have be very careful not to let particles enter the camera or lens. This should clear your trouble, if the camera passed the first step of troubleshooting.
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
Lens stopped working after holding lens when on auto focus
error 99 may be the only error that the camera can identify with the problem. Generally this is dirty contacts in the camera and on the lens. The fix is to rub them with a pencil eraser and ensure no rubber swarf gets inside the camera. ( Hold upside down and use a blower and brush for cameras after doing it. Do the same to the lens contacts and re position turn on camera and see if it works ok now.
Please rate my help++++Thanks for using FIXYA
Jun 30, 2010 • Cameras
2answers
EF-S 17-85 AF jumping around causind err 99
The AF motor is hunting. Clean the contacts on the end of the lens and the camera body with a pencil eraser and try again.
2helpful
Error 99 found what can i do
Heres the fix clean the lens connectors with an eraser (on pencil). make sure the lens connectors are pointing down to avoid dirt and dust being dropped into the mechanism. Same with connectors inside camera Point camera opening at floor. Blow out well after to ensure no rubber shavings are in the camera. Reconnect and turn on it should now stop reporting that error
Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
Error 99 comes while taking photographs
This could well be a serious issue, which you'd need to send to your manufacturer to fix, however there are a few things you could try first:
Take your lens off and with a clean rubber (like on the end of a pencil), clean the contacts of both the camera and the lens.
Error code 99 when using EF 70-200l lens
Error code 99 means the lens is not communicating properly .
You need to remove the lens and clean it . Place it properly . If it is not placed properly you will receive this error .
ERROR 99
try cleaning the lens contacts of your lens and camera.
Top Canon Photography Experts
old marine
old marine
David Shaub
Are you a Canon Photography Expert? Answer questions, earn points and help others
