Question about Makita DPC7311 73cc 14Inch Gas Powered Power Cutter
Which is intake side of piston - Makita DPC7311 73cc 14Inch Gas Powered Power Cutter
Posted by Todd Golden on
Andrew White
  • Makita Master
  • 2,239 Answers
Arrow on the top of the piston goes to the exhaust port.
Posted on Mar 04, 2012
I took the piston out and didnt watch how the piston goes in the cylinder.its got two holes on 1 side does it go with them toward exhaust side or the intake side?
i can 100% tell you that the two windows go on the inlet side of the barrel so they face the carburettor,they are ports for letting the fuel air mixture into the crankcase its known as piston porting when a piston has these holes very popular with yamaha in the 80's
Oct 25, 2015 | Goes Motorcycles
Where is the intake manifold located at"?
It is the top of your motor where your throttle tube connects to the engine..it covers all six cylinders to get air to them...basicly there are three main parts of an engine..the block that holds the Pistons,the intake manifold on top and the exaust manifold on tne sides to allow Pistons to exaust..I hope this helps..if your looking to change replace gaskets..faily major job..good luck..
Feb 22, 2015 | 2001 Toyota 4Runner
Excessive fuel consumption on vw caravelle 2.5i
Clogged PCV Valve
The main purpose of the PCV (positive crankcase ventilation) valve is to recirculate blow-by gases back from the crankcase area through the engine to consume unburned hydrocarbons. Blow by is a mixture of air, gasoline and combustion gases forced past the rings on the combustion stroke. The PCV system usually has a tube leading from the crankcase to the carburetor or intake manifold. Vacuum within the engine intake manifold pulls blow by gases out of the crankcase into the combustion chamber along with the regular intake of air and fuel.
Worn Piston Ring Grooves
For piston rings to form a good seal, the sides of the ring grooves must be true and flat - not flared or shouldered - and the rings must have the correct side clearance in the grooves. Normally, automotive ring groove side clearance should not exceed .002-.004. As the pistons move up and down, the rings must seat on the sides of the grooves in very much the same way that valves must seat to prevent leakage. New rings in tapered or irregular grooves will not seal properly and, consequently, oil will pass around behind the rings into the combustion chamber. Worn grooves are usually flared or tapered causing increased side clearances which permit more than the normal amount of oil to pass the rings into the combustion chamber. Excessive side clearances also create a pounding effect by the rings on the sides of the piston grooves. This promotes piston groove wear and, if the condition is not corrected, breakage of rings lands may occur.
Cracked or Broken Ring Lands
Cracked or broken ring lands prevent the rings from seating completely on their sides and cause oil pumping by a process similar to that described in #7. In addition to this, they also lead to serious damage to the cylinders as well as complete destruction of the pistons and rings. Cracked or broken ring lands cannot be corrected by any means other than piston replacement and this should be done as soon as there is the slightest indication of a crack.
Worn Valve Stems and Guides
When wear has taken place on valve stems and valve guides, the vacuum in the intake manifold will draw oil and oil vapor between the intake valve stems and guides, into the intake manifold and then into the cylinder where it will be burned. If this condition is not corrected when new piston rings are installed, an engine is likely to use more oil than it did before because the new piston rings will increase the vacuum in the intake manifold. When gum or deposits on the valve stems are removed - a procedure recommended when overhauling an engine - the seal previously formed will be removed and leakage will be more pronounced. This is particularly true on overhead valve engines where loss of oil may occur on the exhaust valves as well as on the intake valves. High oil consumption caused by too much valve guide clearance can frequently be cured by reaming or nerraling the valve stem. In some cases new valves may also be required. Use of a permanently bonded valve stem seal will give added insurance against oil leakage on complete engine overhauls or on valve jobs. Large Oil Leaks Leaking valve cover gaskets, leaking crankshaft front and rear seals.
Apr 24, 2011 | Volkswagen Microbus Cars & Trucks
Making sure i'm on the compression stroke
The compression stroke is when the piston is traveling UP and the intake and exhaust valves are both closed.
Intake: Piston going down, intake valve open, exhaust valve closed
Compression: Piston going up, intake and exhaust valves closed
Power: Piston going down, intake and exhaust valves closed
Exhaust: Piston going up., intake valve closed, exhaust valve open
Mar 16, 2011 | Toyota Tacoma Cars & Trucks
I have eh 1989 trail boss 250 i have spark and just cleaned the carb but it still wont start so when i had the carb off i looked in side at the piston while i was rollin it over and it does look like...
I don't have a trial boss 250 but on most 2stroke engines you should never see the top of the piston through the intake port when the carb is removed as the piston doesn't go low enough, thats by design, its the exhaust side you need to look through to see the piston top(crown), if you remove the exhaust to have a look check the condition of the piston rings while there
Nov 26, 2017 | Polaris ATV
Low compression on one side, one fowled plug
A compression leak down test would tell you where the compression leak is coming from, and you should call around to find a repair shop that knows what a compression leak down test is.
A burnt or bent intake or exhaust valve, warped cylinder head or faulty head gasket, or a damaged piston or piston compression ring could cause a compression leak, and a leaking intake manifold gasket that allows oil to enter the intake through the lifter valley could foul out a spark plug, and also it could be a damaged piston or broken piston rings that is fouling out the spark plug.
Jun 06, 2010 | 2005 Ford Explorer
Looking for 2.5 engine on 86 fiero vin r
I just checked Ebay, and there are two listed. You might try Craigs List.
(Tips from me:
Port the Vortec head. Open the Intake and Exhaust ports, by smoothing them out, and smoothing the casting sprue lines out.
Put the Intake gasket, and the Exhaust gasket on the head, (After marking the area with Prussian Blue)
Scribe the opening of the gasket, onto the head, then match the ports to the scribed lines.
You also should round the valve guides top surface. (Where the valve stem meets the guide) There is a square edge that needs to be rounded. This square edge interferes with the fuel/air mixture, as the sharp edge breaks the fuel/air mixture down into droplets.
You want to keep the fuel/air mixture atomized, Not droplets.
Also narrow the casting that comes up the side of the valve guide. (Squared off shape that follows up the guide, and makes the Vortec shape swirl shape in the Intake port) Narrow it to more of a small rounded edge.
Do not polish the Bottom of the intake ports. Leave them as a rough casting. Smooth, and polish the Sides, and Top of the Intake port. (Do not get Extreme! You'll go into the water jacket with your die grinder! Factory may have had a casting shift that day. Just smooth things up)
Makes a nice swirl pattern for the fuel/air mixture.
If you polish the floor, (Bottom), of the Intake port, you will create Two swirl patterns, and they will collide with each other, making droplets again. (They cancel each other out. You want one nice swirl pattern flowing through the Intake port)
I can bring my 1985 Fiero up to 155Mph, (On dragstrip set up for this, tires, and proper safety equipment used). I can also 'Keep my foot' out of the throttle, and get 45 miles to the gallon on the highway.
You can use flat top 350 Chevy pistons. The 2.5 Vin R Fiero engine has a 4 inch bore like a small block Chevy. The pistons can be put on the Fiero rods. Same wrist pin size. The piston drops down into the engine block, about .030 below deck height.
(Wrist pin to piston crown height, is .030 shorter with 350 Chevy piston, compared to stock Fiero piston. You can buy 4 - 350 Chevy pistons AND rings, compared to the price of just the rings, for a Fiero!)
(Thirty thousandths. Real close to 1/32nd of an inch. .03125 is 1/32nd of an inch)
Fiero's have dish head pistons, so the drop in deck height, and using a Flat Top 350 Chevy piston equals out. (Better flame travel with flat top piston. Better burn, more power. Uses more of the fuel/air mixture than a dish head design)
If you can't afford to have them balanced, use a beam scale, and balance them yourself.
I can bring my 1985 Fiero up to 155Mph, (On dragstrip set up for this, and proper safety equipment used). I can also 'Keep my foot' out of the throttle, and get => 45 miles to the gallon on the highway. (Throttle Body Fuel Injection. TBI)
Makes a V6 Fiero cringe!
Sep 14, 2009 | 1988 Pontiac Fiero
03 kia rio-24000 km.will valves hit piston if belt breaks?
yep valves will hit piston if timing belt brake.timing belt keep your valves and piston timed.when intake valves and exhaust valve open.piston is on down stroke.the timing belt keep pistons and valves from colliding.your timing belt change is due at 60000 miles.but in some cases belt need to be inspect at 30000 miles.to be on the safe side.
Jul 20, 2009 | 2003 Kia Rio
Piston ring install up or down Poulan 2150 16"
the groves go into the pins.v is up to fit into those pins.the pins go to the intake side of piston
Jan 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Makita DPC7311 73cc 14Inch Gas Powered Power Cutter Logo
Top Makita Saws Experts
efs_perpends
efs_perpends
ray gallant
Tim Venetis
Are you a Makita Saw Expert? Answer questions, earn points and help others
