Question about Panasonic Televison & Video
To see the picture to your TV from PC you need to set the second monitor to be displayed,please follow the instructions below:
1.right click->properties
2.display setting (you should see a monitor marked 1 and a smaller one marked 2
3.connect the cabels
4.my computer->right click->manage->scan for hardware changes-you should see now two monitors
5.click on smal monitor marked 2,click on "extend this desktop onto this monitor->click Apply->pop up window"Do you want to keep these display setting?" click "yes"
6.if you want to move something from monitor 1 to monitor 2 simply drag-and drop
Posted on Mar 01, 2012
SOURCE: HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Posted on Dec 16, 2007
SOURCE: JVC AV-48WP30, DVI to HDMI on Toshiba HD-A3 HD DVD
If a kit is available it will be expensive to buy and install. Most people can't see the difference between digital cables and component cables
Posted on Dec 23, 2007
SOURCE: HOW CAN I HOOK DVI TO HDMI WITH MY PROJECTION TV
There is a HDMI to DVI attachment you can buy.One thing you need to know is that DVI does not support audio so you will have to run audio cables with it.
Posted on Jul 08, 2009
