It will only print 1 copy at a time in spite of entering 2 or more copies. Also it will print on both sides - one copy at a time. If, however, you enter 2 or more copies to be printed the pringer jams and you have to extract the jammed sheet of paper.
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
SOURCE: HP LaserJet 4700DN Duplexer Jams
hmmm..check the paper for riffling(with fingers before placing in tray)..and the rollers can get slippery, after a period of time...
check your computer warranty for FREE here
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
SOURCE: HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
