Question about Kenmore 16372 / 16374 / 16379 Built-in Dishwasher
Dishwasher fills with water. then hums but dosen't clean
Posted by kevin mcgonigal on
  • kevin mcgonigal Mar 06, 2012
    should the water that fills the dishwasher be above heating element
pcaddict44
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Posted on Mar 01, 2012
Isn't using the soap appropriTely
I would either switch soap and us a liquid soap or fill the reservoir with less soap. A dishwasher does not need to use a lot of soap since it uses very hot water.
Feb 01, 2018 | Frigidaire FPHD2491K Builtin Dishwasher
Dishwasher fills with water.then hums but dosen't clean soap not used
Sounds like your main wash motor is bad or locked up.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch dishwasher turns on but doesn't fill with water and start washing
There is a float in the dishwasher that sometimes gets stuck and when that happens, the washer will not fill. Look for a (mostly round) upright part that will be in the front of the washer either on the left or right side. That is the float and it could be stuck in the cutoff position (caused by the soap). The older models have it on the same side where the soap is placed. The newer models have it on the opposite side to stop that exact problem. MOve it up and down and clean out any dried caked soap that might be under it.
Good Luck
Nov 19, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
How can you tell if the dishwater is getting sufficient water to clean? My soap dispensers are really a mess, lots of dried on soap, and my silverware that are underneath the dispenser often have soap...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 26, 2011 | Whirlpool GU2400XTPS Built-in Dishwasher
I have a problem with my dishwashwer. At the end of the cycle the dishwasher tablet is still intact and the dishes are still dirty. How can I resolve this? ?
The problem you describe points me towards the conclusion that the dishwasher is not filled with water. Another scenario is the motor is seized and not circulating the water.
I do not think that the soap dispenser is broken, as without soap these dishwashers do a fairly good job of cleaning.
There should be a small thing inside the dishwasher called a "float", which is a sensor that stops the dishwasher from filling if it thinks it is full. Try wiggling that and see if soap has jammed up the float in the "full" position. It should be in the front left or right corner.
If the dishwasher hums and sounds different then you may have something jammed in the motor.Start a cycle and look in the dishwasher after the motor starts, is there enough water? (1-3 inches deep).
Aug 12, 2010 | Dishwashers
Husband mis filled ge profile washer dispeser. can we use mixed solution or should we throw it out
Did he overfill the soap dispenser with extra automatic dishwasher soap or with something else? If it is just automatic dishwashing soap then maybe run the cycle with no dishes in it on heavy wash. Now if he filled it with regular dishwashing soap clean out as much of it as you can then run the washer without dishes. If you leave regular soap in there your kitchen will be filled with bubbles.
Sep 13, 2009 | Washing Machines
Kenmore model 665 does not clean dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dishwashers
Does not appear to be cycling water or pumping
You have created a suds lock condition with the wrong soap.
Take a shop vac if possible and vacuum out all water and suds. No shop vac, bail and wipe with a towel.
Then fill with COLD water from the faucet. Start the was cycle a few seconds. Then DRAIN. Repeat with cold water, wash then drain several times until the suds are clear.
You will know the suds are clearing each time you refill with COLD water and start the cycle. It will begin to sound like it is washing and pumping rather than humming.
May 05, 2009 | Dishwashers
Dishwasher
Let it fill with water then add 1/4 cup of vegetable oil. Let the washer run a few minutes and open the door to see if the suds are gone. If so, drain the washer and run it through a short cycle with small amount of proper detergent to clean any oil residue from tub.
This will also work for clothes washers that oversuds.
Nov 14, 2007 | Dishwashers
Kenmore 16372 / 16374 / 16379 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
gbob59
Paul Carew
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
