Question about Sony Alpha DSLR-A200 Digital Camera
I have a sony a200, i want to fit an external flash for that.
I have a sony 200 and want to buy an external flash...I heard for that you need a hot shoe to fix the same with your camera. Can anyone let me knw what else i need to buy to fit the external flash with my sony a200
Posted by subha on
Larry
    Habit-Forming:
  • 126 Answers
I have use an old Osram side mount, the biggest issue you face is the syncing. I learned to make my old flash a slave and let the little built in flash drive the side mount.
I did buy a Hot shoe mounted flash it has to be compatable with Sony. It uses infared to focus no firing of flash. In low light you will hear the lens seeking a focus point.
Research flashes I use one that has ability to tilt up and has a diffuser shield good for those wide angle shots.
the money spent on a good flash will enhance your pictures.
Posted on Jan 08, 2015
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
The camera already has a hot shoe that will accommodate a Sony flash unit or a third-party flash unit designed for Sony cameras. You don't need anything else (other than the camera and the flash unit, of course).
Posted on Mar 01, 2012
Can u fit a vivitar series 1 to a sony a 200
Vivitar Series 1 lenses were available with a variety of lens mounts. A lens with a Minolta mount will fit a Sony a200. A lens with another mount will not.
Nov 02, 2012 | Cameras
Do you have availability of a Sony ax 200 User Manual please?
You can download the manual (and more) for the Alpha 200 from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSLR-A200®ion_id=1
Jan 04, 2011 | Sony Alpha DSLR-A200 Digital Camera
My camera don't want to make photos with the flash. I activate it from menu, i opened it manually and the picture is without flash. Why?
The camera does not flash. Solution
sp.gif sp.gif Follow this procedure to troubleshoot the camera not flashing.
  1. Select the correct flash mode . NOTE: When set to the Forced Flash setting, the camera should flash for all still pictures.
  2. Perform a reset procedure .
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada United States Products
sp.gif sp.gif DSCF828 Last Modified Date: 03-04-2010sp.gifID: C322716 document.write(""); ---
How to troubleshoot an external flash that will not work. Solution
sp.gif sp.gif IMPORTANT: Depending on the mode of the camera, the external flash may not be available. Refer to the instruction manual of the camera for more information.
  1. Ensure the external flash is properly inserted into the accessory shoe on the camera.
  2. If using the connection cord, ensure it is properly attached.
  3. If the external flash uses batteries, ensure fresh batteries are installed.
  4. Ensure that the POWER switch on the external flash is set to ON .
  5. Ensure the hot shoe setting on the camera is properly set for the type of external flash and camera being used. NOTES:
    • When using a commercially available standard external flash, ensure the hot shoe is turned on.
    • If a Sony external flash is being used with an advanced hot shoe on a Sony camera, ensure the hot shoe is turned off.
    • It may be necessary to refer to the instruction manual of the camera and external flash for specific information about the hot shoe.
  6. Ensure the READY lamp on the external flash is illuminated.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Mavica Last Modified Date: 03-04-2010sp.gifID: C292057 document.write("");
Jul 23, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Hi i have a Sony hdr CX550 handycam camcorder
Most mics will work if the plug fits the socket on camera and it fits on the hot shoe okay, I never use Sony mics on my Sony camera, you end up paying for the name, not the item.
Jun 19, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sony 200 manual
dont even try to do this yourself send it back to sony let them do it,,, the lcd is very very easy to crack if you dont take geate cear and for what they cost, is it worth the risk???
Oct 24, 2009 | Sony Alpha DSLR-A200K Digital Camera
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Can not upgrade firmware v1 tov4 in a Sony a200.
there is know update in firmware for a 200 the v4 update is for the a700
Mar 16, 2009 | Sony Alpha DSLR-A200 Digital Camera
How to Replace a harddrive on a sony vaio v300g.
hi yes you can you need to to know what type 2.5 or 3.5 does  your machine have an maxiume size for the drive you know also you need to install the os again do you have all the disc, if not you can transfer most info off
you can also buy an usb cable which will allow you to connect to external devices from harddrive to disk drive
cheers
Dec 13, 2008 | Sony VAIO PCV-V200G PC Desktop
Minolta 5600 flash on Sony A200 camera hot shoe problem
This is what you need:
http://cgi.ebay.com/TTL-Cord-Flash-Bracket-Sony-Alpha-A700-Digital-Camera_W0QQitemZ290258666395QQihZ019QQcategoryZ48515QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
it screws into the mount underneath your camera, connects via a cord to your hotshoe mount, and your flash willl then sit next to your camera mounted on this flash bracket.
Sep 12, 2008 | Konica Minolta 5600HS for Maxxum Minolta...
Based on A2 vs. S7000....
I have an S7000 and I love the camera. Still, there are other grear buys today in the stores. Prices are falling down for some great cams. One of these cameras is the KM A200 that is at a reachable price category for me. I am thinkink about changing my S7000 to an A200 and would like to ask your opinion of this idea. I know all the physical data and specs and the A200 simply meet my needs. There are some things that the specs sheets don't reveal: - General operation - how responsive in use? - Low light / indoor AF - Flash recharge time (shot to shot speed with flash) The advantages I see for the A200 are (compared to my S7000): - Wider angle lens (28mm) - Flip-out and twist LCD - Cleaner low ISO performance, usable ISO800 at full CCD resolution - 8mp for cropping - Larger sensor, less noise - 800x600 video (though 15fps) - Manual zoom ring - More manual settings, user memories on mode dial And these are the pros for the S7000 (compared to the A200): - Better shot-to-shot speed based on test numbers - Better battery life - Faster lens at tele - More flash power - Accepts 3rd party external flashes - Less barrel distortion at wide angle That's it. Waiting to hear what you say. If there is any of you used (or tried) both cameras, pls share your experiences with me.
Sep 07, 2005 | Fuji FinePix A200 Digital Camera
Sony Alpha DSLR-A200 Digital Camera Logo
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
