Olevia LT32HVE 32 in. LCD Television Logo
Posted on Mar 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot set color - Olevia LT32HVE 32 in. LCD Television
Level 3:
Top Expert:
  • Olevia Master 76,851 Answers
  • Posted on Mar 01, 2012
Olevia Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006139
Points
237762
Hello
Enter into the Menu options, surf through, and come to picture adjustment window. Here you can set all adjustments to picture.
Print colour pictures from laptop to printer
If your printer can print in color and your printer is set to print in color, then you need to do nothing else, it should print in color. There are only 4 things that could prevent you from printing in color. 1. The printer settings is set to print in shades of grey. 2. The printer itself is set to print in black and white only. 3. There is no more ik in your color cartridges. 4. You don't own a color printer.
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Need to set the color to 6500K
No, the manufacturer is the one to contact on what resolution is best for your project.
Most monitor are already set for best resolution for photos and movie view and also media editing so you should be OK
if your monitor is a recent model at 16500X780 or it says that is 1080p or 1080 i then you should have no issue with the color setting.
You can go to the control panel and set the display settings for hue, color , contrast and brightness if your Monitor has a graphical user interface for it. Check your user manual for color adjustment for your monitor and also the video card that is install in the PC.
The "control panel will have the display setting for "true, and High color resolution.
1helpful
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Vo370M no color on dvd color on tv godd but only
Please change the display settings on DVD, the settings is not NTSC only set PAL then color Display will apear
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
1helpful
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Color setting
MOST likely, use remote [maybe set] for <menu[setup]> <video>. This is normally where <brightness><contrast><color> and so forth live.
Samsung DLP HL-R5667W
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
