Washing Machines Logo
Question about Indesit W 83
Indesit w103 dial keeps clicking around
Dial for programmes keeps clicking and not setting to any programmes
5 Related Answers
wagdom
keith wagstaff
  • 64 Answers
SOURCE: Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Posted on Oct 31, 2007
Anonymous
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
Anonymous
  • 1294 Answers
SOURCE: INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Posted on Jun 05, 2008
Anonymous
  • 97 Answers
SOURCE: INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 06, 2008
Anonymous
SOURCE: indesit wm2x
We had similar fault.
Rectified ours by switching off at the mains and put dial to one of the dots. Switched on and it reset.
Good luck
Posted on Dec 08, 2008
1helpful
Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Hi.I have a indesit washing machine model W103.It seems to run part way through it's cycle until it needs to drain.The program dial then starts clicking around.Someone suggested that it could be the belt??...
I would say, place a voltage tester on the pump motor wires and see if there is power to the pump. If there is, replace pump as it is defective.(very common problem). If not, your timer is unfortunately needing replacement. Let me know.(This is on the drain cycle when testing).
5helpful
Indesit w113 and w1101 wasing machines dial clicking round
This type of fault is usually associated with a faulty programmer. if you have a reset point, then try to reset it, if no reset, then programmer is faulty.
Please rate my solution.
Thanks.
1helpful
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
1helpful
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
1helpful
2answers
Indesit w1 13 reset
If your washer has some black spots on timer dial then set your dial pointer to one of these spots to reset programme.
Then try it again, if it still does the same thing, then you probably have a faulty control module.
Expensive!!!!!
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Washing machine wont do anything
rotating timer knob indicates that there is a fault, obviously, so its a case of going through a checklist, based on info given, check in this order, outlet pump, for open circuit, then heater element for open circuit, then maybe the water valves, you have given little information for me to go on as an engineer, please understand, the more you say the more detail we can give ..... ok cheers with looking for the fault, best of luck and work safe
Top Indesit Washing Machines Experts
Marvin
Marvin
sheakhly
Level 1 Expert
mark warfield
mark warfield
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
