Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Check to see if you can turn drum by hand, if you can, then prob could be belt, or motor not turning under load, check brushes in motor.
Please rate my solution.
thanks.
Your drive belt tension may be set too loose or the belt itself is going bad. If you have a spring loaded tensioner, that may have weakened as well. Bottom line is that when belt is not tight enough, the normal load from the compressor added to the extra load on the pump when turning causes the belt to slip (making noise) Eventually, it may begin making noise when started as the alternator demands more power in order to work (you likely have heard cars with this problem in parking lots...loud screech right after starting) Wish I remembered which method they use to restore tension on yours butyou can easily get that info in any inexpensive manual (they may even allow you just to browse it without buying)
Sounds like it an outer cv joint on that side. They start making a ticking noise under load and it gets worse as time goes on. Have a shop look it.You'll need a pretty well stocked tool box if you want to do it yourself.
