What kind of capacitor do you need? There are all kinds of capacitors in our daily life such as a parallel plate capacitor that can store electricity. If you need one that can have the function of cool or heat. You can check which type of capacitor is coolant? This website has lots of knowledge about capacitors: https://www.apogeeweb.net/electron/parallel-plate-capacitor-basics-and-formulas.html Hope this can help you.
Turn power off at disconnect box. Should be outside by the a/c condensor. is this a run capacitor or start capacitor? if it has two brown wires it is a run capacitor if it has 3 wires such as red, black and brown it is a start capacitor.
Even with the power off the old capacitor may hold a charge. To discharge Take a tool with insulated handles such as a screwdriver and touch all post at the same time. Remove the two or three wires usually both brown one may have a white stripe or three wires make sure to make note on what terminals each color came off of on a start capacitor. On a run capacitor only two wires do not need to mark as they can be on either post . Take this to a HVAC parts supplier in your area. The information on the side of the capacitor will insure you get a proper replacement. have them test the capacitor they should do this for free to insure the capacitor is bad. Reinstall secure wires and turn power supply back on.
hi, to replace the capacitors need to take the board out, by removing the screws and disconnecting the wires braids. You need bread, tin and absorbs tin. You should take the tin from the legs of the capacitors, until it can release the capacitors outside the board. Next, you put the new capacitors in place. Should pay attention to put the capacitors, by proper polarity of plus or minus. It is important to be precise with the value of capacity and try to put a capacitor with a value of slightly higher voltage, temperature resistant to 105 degrees.
