MOBO: ASUS M2N MX CPU: AMD Athlon 64 Dual core processor RAM: 1 GB Problem: When I start my system the display won’t come up, even though I am able to see the fan running and the power supply is intact and the green light on the motherboard also lights up the display won’t come up. Initially I thought there might be problem with Monitor but the monitor worked fine when I used with other system. I removed CMOS to remove any settings which I may have done but no luck either. Please help. If I require changing my MOBO which would be the best choice with reasonable price and compatible with AMD, Can I use Intel Mother Boards?
SOURCE: AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
SOURCE: ASUS p5vdc-MX motherboard won't boot
The light is probably the power light which is ok, but from past experience it sounds like the board is dead for one reason or other. Is it still under warranty? If it is take it back to where you got it, with the purchase docket if you have it and talk to them about what you have tested and ask for a replacement. If it is out of warranty, try ebay or use www.staticice.com.au to search for the same motherboard if you want to rebuild the system without having to reload windows.
SOURCE: My ASUS P5SD2-VM Is Having A No Display Problem
Pls check the moniters cable. otherwise chek the display device in motherboard
SOURCE: Asus M2N-E SLI
In my experience, there are some fans that are loud. It could be bad bushings or possibly a fan that is out of balance. The Cool and Quiet utility will not solve that problem.
Are you sure it's the CPU fan?
If the computer (or it's parts) are less than a year old, they should be under warranty.
If it's the case fan, I'd replace it with either a new single-speed fan or one that has a variable speed adjustment.
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
