How do i change the dvd format from ntsc to pal
SOURCE: how to unlock it to play either NTSC/PAL
Here is the sequence to unlock your DV Player. Clearly this needs to be done exactly to access the secret menu. So, you may want to copy and paste this info into a word program and then print it.
- Begin -
1. Turn off NS55P, leave TV on.
2. Using the original remote supplied with the NS55P, press these buttons in order: DISPLAY, TOP MENU, CLEAR, POWER.
3. NS55P will turn on, displaying the secret menu on the tv screen.
4. Select 2: Drive Manual Operation, then 4: Tray Aging Mode.
5. The screen then shows two input lines: Input Count and Current
Count. Use the code 00030 on the first line. Pressing zero first will
take you back to the original menu, so instead of trying to type
0-0-0-3-0, try something like 1-0-0-0-3-0 so the 1 in the front
disappears after the last zero is entered.
6. Press ENTER on the remote. Disk tray will then open and close automatically 30 times. Let it do this until it finishes.
7. Repeat steps 4-6, but instead of using 00030 in the Input Count,
use 00000. Press ENTER, and the NS55P is now capable of reading Region
2 dvds.
- End -
Please ask any questions using the comment box below.
Regards,
Worldvet
SOURCE: Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
SOURCE: PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
SOURCE: PAL to NTSC
I think your remote control can help you with that. You can switch to PAL or NTSC depending on what will work best. What do you think?
SOURCE: Won't play ntsf dvds in colour
if your dvd is ntsc compatable then in your dvd settings menu change from Pal to either auto or ntsc also it might be that your tv needs to be changed in the same way
