Computers & Internet Logo
Anonymous Posted on Feb 29, 2012
I have lost my installation cd for my geforce 8400 GS DMS PCI-e graphics card
Anonymous
Level 3:
  • Master 871 Answers
  • Posted on Mar 01, 2012
Anonymous
Master
Level 3:
Answers
871
Questions
5
Helped
364060
Points
2104
Here is a link if your OS is XP = LINK
here is a link if your OS is Vista/7 = LINK
these are 32bit drivers, if you want the 64bit drivers, go HERE
hope these helps.
5 Related Answers
Anonymous
  • 219 Answers
  • Posted on Feb 04, 2009
SOURCE: added a ge force 8400 gs pci grfx card to hp a6120n monitor
Alright, let's give this a shot. Your system can handle it as the card only needs 71W of power.
Right-click your desktop and go to properties.
Screenshot.
Afterward select the tab at the top reading, "Settings."
Screenshot.
Now select your new video card in the, "Display" region and choose the device to be your, "Primary Monitor."
Screenshot.
Afterward try plugging the monitor into your new graphics card. It should work just fine.
Anonymous
  • Posted on Jun 04, 2009
SOURCE: Blank Monitor
I have the same system and card. The problem is the system is trying to run two monitors at once. Use Windows safe mode (F8 during boot) to uninstall any Pny drivers you may have put on. Reboot. Install the pny drivers again. Before rebooting, use the device manager to look at the display drivers. There should be two, an Intel one, and the pny Nvidia one. Disable the intel driver and reboot. Worked for me. Youmay also want to upgrade the power supply. The 3000 has a 225W and the 8400 card wants at least 300W.
Anonymous
  • 285 Answers
  • Posted on Jun 08, 2009
SOURCE: Trying to install Geforce Verto 8400 GS card on
Seems like the graphics card simply isn't compatible with your motherboard either. However, have you tried installing the drivers for the new card with the old one still in, then inserting the new one, and booting up? That's the only thing I can think of that you didn't try yet...
Anonymous
  • 117 Answers
  • Posted on Jul 10, 2009
SOURCE: i have a geforce 8400 gs pci interface. the
Hello gabini248,
Disabling "restart on system failure" may fix the problem: Right-click on My Computer, click Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box at “Automatically restart.” You may have to restart your PC for the effects to take place.
Robert Hopkins
  • 97 Answers
  • Posted on Jul 30, 2009
SOURCE: nvidia geforce 8400 GS pci code 12 error not
Error code 12 is one of those errors I hope you won't ever receive, because fixing the problem can be rather difficult. There are two different things that can trigger this error. The most common problem is a resource conflict. Essentially, this means that two hardware devices have been assigned overlapping resources.
A corrupt Multiprocessor System (MPS) table can also cause error code 12. If the MPS table is corrupt, it can cause the BIOS to allocate insufficient resources to hardware devices. I have had a really tough time locating information regarding a solution to this problem. From what I have been able to tell, though, it appears that an MPS table can become corrupt as a result of a damaged hardware abstraction layer (HAL). If that is the case, then reinstalling Windows may fix the problem.
In plain English :D either you have 2 pieces of hardware trying to use the same resources (unlikely), or you have software that is trying to run the same driver twice. I believe that about the only way you are going to get rid of that message is with a clean install. Even then I wouldn't guarantee it.
2answers
Does the DG31PR motherboard support Geforce 8400GS 512MB PCI-E?
Yes, but check your BIOS and make sure the PCI-E slot is enabled.
Also, when you say doesn't start, you mean just the screen? Right?
I need help with a nividia 8400 gs
see that ur vga cable is inserted on a graphic card
and reset ur cmos
Looking for nvidia xfx geforce 8400 gs drivers
hi throw your cpu in the bin and you parents will get you one
I got the this pny geforce 8400 gs pci card but it sends nosignal
You need to install the driver that came with the card. If you don't have it you can download it from the site. Also (for experienced users), check your BIOS setting to see if it has an option to select between the integrated graphics card your other one.
Nvidia Geforce 8400 GS (PCI)- easy installation is not so easy.
What sys prog are you running, rem not all progs are compatible. ie Vista? Pain the u no were!!
Some games, like Hitman stop running under nvidia 8400 gs
Update/ reinstall the driver software. but it looks like you need a new graphics card
Grand Canyon Tech
Grand Canyon Tech
