Not for free:
- ford-falcon-1996-1998-workshop-manual
- austech.info/26116-ford-ef-el-service-manual (its page 2 post 39, is still active; I might add, i think you need to be a registered Austech member to view the link for those looking for it).
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: Replacing front wheel bearings
It isn't a particularly hard job but there are a few techniques that you need to know.
I wouldn't recommend you do it yourself but I would recommend you do it under supervision of someone who knows their stuff.
Retensioning the bearings correctly is extremely important.
SOURCE: ford falcon el. wont start. raa checked has spark
Most older cars have a mechanical fuel pump mounted to the side of the engine. Usually turns from the Cam or Crankshaft. i would check under the Valve Cover area. should be a small pump that is mechanically driven by the engine. probably half the size of your fist. Trace the fuel line from the carb to it. most oder cars have this set-up. I hope this helps you out. Never worked on a Ford Falcon. My 74 dodge B100 had that as well as my 78 Lemans. Good Luck!
SOURCE: firing order for a 1996 EF ford falcon
EF & EL are 1,5,3,6,2,4
EF has a coil pack under the inlet manifold the EL has a distributor
EF uses a waste spark system so 2 plugs are fired at the same time eg 1 & 6 - 2 & 5 - 3 & 4
SOURCE: timing belt on el ford falcon
Just put it on tensioner arm does the rest use a 3/8 drive ratchet
SOURCE: Ford falcon 4.0 litre fuel injection, backfires
i have a 96 xh ford falcon 4.0 ute.I am rebuilding the engine and delated the pic i had of the timing set up . I am after a pic or a site that i can see where the timing marks should be. I know that the crank of cause is tdc.(key is on top) cam marker is at 3 o'clock (90 degrees from top). Where does the dizzy gear timing mark point to?
