Question about Dell Dimension E520 PC Desktop
No power lightning hit my phone wire after that i couldnt get my pc to power up all i could see inside was a dim amber light glowing but the power button did nothing when i pushed it in .
Posted by ford98b on
  • 1 more comment
  • Brian Sullivan
    Brian Sullivan Feb 29, 2012
    sounds like it might have fried the motherboard did you smell anythingdid you have it attached to a short circuit board                                       it might have just fried the PSU power supply unit the light on only means its still getting minimum power for the light you could use a multimetre to check voltage coming from the PSU  also look at the test switch for burned or black marksopen up your computer to have a closer look look for any black or chared wires hope it helps you
  • ford98b
    ford98b Mar 02, 2012
    i took the back off checked wires and boards dont see any burnt marks and when it happened i smelled nothing .everything else i had plugged into the surge protector was fine the pc is the only thing that wont come on and was hooked through the ethernet to the phoneline. the power button wont even stay in when i push it to power up thinking now could it be power supply or maybe pc went to sleep?
  • ford98b
    ford98b Mar 05, 2012
    ok i didnt see a reste on the power supply all there is is a red thing has 115 on one side then 320 on the other when i flip it over but no fuse reset?I also looked at the mother noard when i plugged the pc back in and the amber light that is on is on the mother board it just comes on when i plug it in still no power to the on button it wont even stay in when i try it
Walter H Boehm
  • Dell Master
  • 998 Answers
Since you said phone wire, I'm assuming you have a dial-up modem card to connect to the Web. Look at the card that the phone wire plugs in to. Try removing that card and power on the computer.
Posted on May 04, 2014
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Posted on Jul 27, 2008
Walter H Boehm
  • 998 Answers
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
Anonymous
SOURCE: When I push the power button, the power light stays amber.
Does your computers power supply kick on or the fan. If not at all there is two tabs on the motherboard. They are small and blue located at the bottom left and just to the right of the first one. they should be connecting a set of pins together on the motherboard take the left one completely off and leave the right one in the same spot. Try the computer again it should kick on. If not replace pin to the left 2 pins instead of the right for a computer reset. Then hit your power button. wait 3 minutes then take the pin back off and put into the normal position. Computer should kick on and run properly.
Posted on Jan 05, 2009
Anonymous
  • 219 Answers
SOURCE: Dell Dimension 9200 PC will not power on
Well, either way it sounds like something in your motherboard or your system got fried. Either a surge occurred frying some if not all components (yes, voltage can still flow through them even when they're dead allowing things such as the LED on the motherboard to glow) within the computer, or your PSU blew out taking some components with it.
Due to what you're describing, I'm more inclined to believe your PSU blew out due to some form of an overload taking your motherboard (if not more components) with it. An overdraw of power on the PSU or just a cheaply constructed PSU will easily blow taking some of the components with it (essentially killing the components).
Sorry if this is not the solution you were after. However, everything you described matches with either a power surge or a blown PSU. Always sad when perfectly good electronics get fried. Let me know if I can help you with anything else.
Posted on Mar 22, 2009
Anonymous
  • 137 Answers
SOURCE: My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Posted on Sep 03, 2009
Testimonial: "Very detailed advice, thanks! I believe my motherboard is bad, after testing with your suggestions. "
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
I have a compaq persario m2000 my wifi light is on but i cant get to the internet, its telling me Internet Explorer cannot display, the webpage please help thanks
There are two lights for the WiFi, Amber and Blue. the following explanation is from HP's website.
An indicator light c01525482.jpg glows blue when the Bluetooth or WiFi communication devices are turned on. If the computer has both Bluetooth and WiFi and one of them is turned off or the device is disabled, the light glows amber. The indicator light does not glow at all when power to the device is turned off. The HP Wireless Assistant software must be used to enable or disable the individual wireless functions.
Dec 30, 2012 | Computers & Internet
Computer won't turn on!
what it might be is that your hardrive or power supply is not working and that you need to have it replaced
soory i couldnt be of more help!!
Jul 22, 2010 | HP Compaq d530S PC Desktop
Dell Dimension 4400 - Power light glows amber when attempting to power up. I'm thinking it's the power supply. Is this something I can fixeplace myself?
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
A solid power LED is either a bad component connected to the motherboard or a bad motherboard
May 13, 2010 | Dell Dimension 4400 PC Desktop
My dell was hit by lightning and now i cant get it to boot up
hi there;
really,lightning has a great power voltages supply,thousand of volts was supplied in one strikes of lightning.this depend how much voltage was induces on your computer,mostly your avr and psu might be damage by checking if there is power determining the fans inside avr and psu if running maybe you have the power,and some led light are blinking ,some how to be sure you can use multi tester if you have knowledge on this.basic approach if you have black out screen and good power supply,pull out ide cable of hardisk and cd room from mother board,you can run pc w/o them to check your start windows if will open run your pc if still black screen,take another video card and memory card try to replace them and rn your pc,if windows open fine if not maybe you have damage the mother board from lightning.replacing defective devices can put back your windows open.best regards
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Dell Dimension E520 PC Desktop Logo
87 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
