Question about Akai PT4298HD Rear Projection Television
I have a vertical line in my rear projection TV - Akai PT4298HD
I have a vertical line in my rear projection TV. The problem came about "after" replacing the convergence board. My TV was not working, then I put in the new convergence board which made the TV work. Unfortunately, I now have a vertical line as shown in the pictures. I tried a second convergence board, and the problem persisted. What could be causing this problem? Is it simply a calibration issue that could be fixed with the onscreen programming? Or is it something physical inside of the TV itself? What is necessary to fix my problem? Thank you!
Posted by gofastrack on
paul fairbanks
    Genius:
  • 1,147 Answers
Looks like you have a problem with the crt itself poss a fractured shadowmask the convergance system only changes the magnetic field in the scan coils to realign the cathode guns to keep the scanning in line . coincidental i think, a new crt is favorite hope this helps
Posted on Apr 13, 2017
5 Related Answers
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: AKAI PT4298HD
If you have a good picture except for a missing color all the various circuits are working OK. Most likely you have a bad solder joint or component in the red circuit. This would also be indicated by the fact that ocassionaly the red pops in. If you have the experience remove the boards and inspect for cracked or cold solder joints. Resolder anything that looks suspicious. If this does not fix it you will have to troubleshoot the red drive circuits from the CRT back to the video IC. Another possibility is that you have a bad/intermitant red crt. I doubt that you have the equipment to check this but you can test it by moving the green crt board to the red crt. If it now works the red crt is OK. If all this fails you will need to find a reputable repair shop to look at it. If the unit is more than 5 years old it may not be worth fixing. Good luck.
Posted on Jun 13, 2007
Vista Electronics
  • 1694 Answers
SOURCE: A Remote Control for a akai pt4298hd
www.mremotecontrols.com ....T.
Posted on Dec 14, 2007
Ronnie Houston
  • 2920 Answers
SOURCE: I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Posted on Sep 17, 2008
Anonymous
  • 100 Answers
SOURCE: Akai 42in rear projection TV convergence problem
its the problem of ic on the main board..ic needs to be replaced.not much expensive.
Posted on Dec 24, 2008
Anonymous
  • 145 Answers
SOURCE: my akai pt4298hd is out of zoom and
akai is a samsung tv. you have a defective convergence board. suggest local service center. sorry
Posted on Nov 14, 2009
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
My akai pt4298hd is out of zoom and
Nov 14, 2009 | Akai PT4298HD Rear Projection Television
Vertical line on rear projection TV - Akai PT4298HD
this is an indication of a burnt crt. unfortunatly to fix this the crt will need to be replaced. such a repair is something i would recomend to a non tech. theres adjustment issues
Oct 30, 2008 | Akai PT4298HD Rear Projection Television
Akai PT4298hd
You may need the change the coolant in the blue tube. Convergence is when the picture will look 3D Let me know if you need more information.
Apr 25, 2008 | Akai PT4298HD Rear Projection Television
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Akai PT42198HDX/SMS
Set could just be way out of adjustment or there is problem with video circuit
Jan 16, 2008 | Akai PT4298HD Rear Projection Television
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Blue Line
Sorry no bulb issue here. theres a vertical sweep issue though. if your not a tech i wouls sugest that you find a good one as this is a solid state set and there are no user replaceable parts inside, so you cannot service yourselfs unless your trained to do so. please seek out a trained tech to assist you in this repair.
Sep 22, 2006 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
87 people viewed this question
Top Akai Televison & Video Experts
Ekse
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
