SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge? I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door. Let me know if you need more help. Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
SOURCE: lg refrigerator LFX25960SW
the answer to the problem from a LG training class is... if the bottom left side of the refer is freezing food the liner has split no fix at this time. some people have beEn able to turn off the ice maker and the food will stop freezing. the ice maker has a fan in the freezer that blows all the cold air up the ice making Cobby.
DO THIS ONLY IF OUTA WARNTEE
for most of you with bad ice makers you could drill a hole in the very bottom of the ice maker towards the front right under the little metal arm in the wight plastic AND DONT DRILL DEEP just enough to put a hole in the outer case then hit it with a blow-dryer for a little bit to remove ice that's blocking the gear on that arm this works 5 outs 10 times
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
SOURCE: LG french door refrigerator ice maker
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
