I think that I did something wrong while fixing the well known magenta issue with this printer but I still don't know what. The fading problem is now gone... thanks to this website (http://www.reeves-hall.net/tech-gadgets/fixing-washed-out-colour-on-hp-color-laserjet-2605/). All 3 colors are now working perfectly well, but black is no longer printing at all. Any idea ?
SOURCE: can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
SOURCE: Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
SOURCE: LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
SOURCE: HP Color LaserJet 2605 dn
Only experts can do this job, if you are confident down load the manual then start.best of luck...
