Question about Sennheiser HDR 120 Consumer Headphones
Sennheiser hdr 120 - one earpiece has no sound. what should I check?
Posted by rljdd on
  • Dave May 10, 2012
    Hi - did you find a solution to this problem? I have the same thing - no obvious cause.
  • Dave May 10, 2012
    HI - did you find a solution to this? I have the same problem with no obvious cause
E.R. Whitford
    New Friend:
    Problem Solver:
  • 7 Answers
Wiring
Posted on Feb 28, 2012
Sennheiser HDR120 - missing transmitter / alternative OR replacement?
The system is working in the 860 Mhz range, so not that common. Most of the time it is cheaper to by a complete new system then to tray to buy components. Just keep looking in the thrift stores you find a transmitter for this headphone for a good price.
Jun 15, 2014 | Sennheiser HDR 130 Consumer Headphones
I have Sennheiser 120. Set it up right. One side or the other comes in clear. Never both sides at the same time.
I have a set as well but the batteries were weak and it was doing the same thing when they were new. Replaced with good batteries and that was the problem. if you try this and they still don't work then just return it for a replacement
May 17, 2014 | Sennheiser HDR 120 Consumer Headphones
Sennheiser 120 green light goes off
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Nov 12, 2017 | Sennheiser HDR 120 Consumer Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
HDR 120 PHONES. Sound on right phone has dissapeared but right phone is ok. Batteries have been checked and are fully charged. Any suggestions. I have checked all the connections and all look solid on both...
Hi, What test did you preform to know the right phone is OK? Connections can look solid to the naked eye but not be the case. What are you using to test these phones? Make sure the the plug you are plugging your jack into is functioning properly so you know you will get a proper test of the phones themselves. With the phones on your ears and plugged in and music playing can you wiggle any of the wires or connections and hear any crackling? This will give you a good starting point to address. Good luck.
Mar 06, 2011 | Sennheiser HDR 120 Consumer Headphones
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Dec 27, 2009 | Sennheiser HDR 120 Consumer Headphones
Have not used them for a while
These systems have some signal detection, so needs an input to fire it all up. That is the same for the greenlight, when initially switched on for my HDR 120.
Dec 26, 2007 | Sennheiser HDR 130 Consumer Headphones
Sennheiser HDR 120 Consumer Headphones Logo
Top Sennheiser Audio Players & Recorders Experts
Marvin
Marvin
Vernon Taylor
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
