SOURCE: D-Link DIR-625
What you need to do is long into your router's configuration. For the D-links, all you have to do is open internet explorer. Type in 192.168.0.1 on the address bar and press enter. Once you get into the log in page, type in your username and password (not the same one as your wireless password). If you don't know. Try admin for username and leave password blank. It should work if you have not change the default password. Once inside the configuration page. Go to Advance, click on QoS engine on the left. Input the IP address of the VoIP box in the "source ip" , type in a name for your rule and select 1 for priority and input your ports for your VoIP box. The best thing you want to do is put your VoIP box before your router. That way you get better quality.
SOURCE: Dlink DIR-625 permanently stopped
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
SOURCE: Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hello, have you tried to plug it directly to your pc? you need to configure it first before you can use its wireless capability, to configure it just plug the end to your oc or laptop then type 192.168.1.1 on the address bar of your browser
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
