Question about OKI C5400 Laser Printer
How to fix error 491: Tray Empty on Oki c5400
The tray is full, but the display saids empty
tonio
    New Friend:
Printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Posted on Dec 02, 2015
5 Related Answers
Anonymous
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
Anonymous
  • 1665 Answers
SOURCE: Okidata 5100C error code 490:MP tray empty
http://www.fixyourownprinter.com/reference/errorcodes/okidata
Posted on May 28, 2008
Jeff Hughes
  • 97 Answers
SOURCE: oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Posted on Dec 07, 2008
vidiot1961
  • 24 Answers
SOURCE: Oki B4600 ONLY prints to rear tray - how to print to front?
Yes. click on your printer icon. select properties then look for Tray or Output Tray or Tray settings and change it
Posted on Jul 08, 2009
Anonymous
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
3answers
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Jura z7 error message empty coffee tray when tray s not full
Yo James,
I know nothing of your unit, but I've never let that stop me before??.
Sounds like a sensor is stuck in the "tray full" position and popping an error message based upon what "it" is detecting.
OK, how does the unit know from "full tray" (what ever that means). I'm a big believer in problems being created by dirt, crud and in your case, coffee grounds. Unless the sensor (switch?) itself has failed, I'll bet there is debris fouling the system.
Find the "full tray" (what ever that means ??) sensing mechanism and clean/replace it and I'll bet you will solve the problem.
All the best.
Oki c5300 tray 1 empty but I have paper in tray 1
there is a black sensor flag that will hang down from printer when tray is removed. verifiy it moves freely
3answers
Empty Tray
Hi all, I have the exactly same problem on my Gaggenau CM470 however the drip tray is clean and the contacts in the back is also 100% clean.. I wonder if its possible to disable the sensor/switch on a CM470 ?
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
2answers
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
1helpful
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Okidata C5200 error 491
You say you have checked properties etc but have you selected mp tray from printing preferences in the driver. Remember the driver overrides the printers own settings.
My oki printer
Make sure you specify the correct tray from your application. Tray 1 might be refering to tha manual or bypass tray.
OKI C5400 Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Ekse
Alvin Barnabas
Alvin Barnabas
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
