Question about Microsoft Windows XP Home Edition English for PC
Windows xp 120 dpi install fonts? - Microsoft Windows XP Home Edition English for PC
1 Related Answer
kershk
Kevin Kershner
  • 106 Answers
SOURCE: Changed DPI settings; can't change it back
drop in to Safe mode and reset video from there
Posted on Jun 09, 2009
Normal size for dpi
DPI, or "font size" is variable, depending on your monitor's native resolution, The resolution you have selected for it in Windows (Desktop-->Properties[right-click]-->Display Properties-->Settings), and what program you are currently using (browsers can be "zoomed").
I would try adjusting your monitor resokution first, before changing display font size. Try this page for some help with XP: http://www.andybrain.com/qna/2008/02/09/how-to-change-the-font-size-in-windows-xp/
This page for help in Win7: http://www.sevenforums.com/tutorials/443-dpi-display-size-settings-change.html
There really is no such thing as "normal" DPI font size. Most people with decent eyes would probably use 96 as a standard.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
How do you change the font size on the computer?
@mychelemyche
Try the following:
For Windows XP
1. On the Desktop, right click on an empty space and select Properties.
2. A Display Properties window will open, click on the Appearance tab and on the Font size drop-down, choose Large Fonts or Extra Large and click Apply.
For Windows Vista.
1. On the Desktop, right click on an empty space and select Personalize.
2. Click on Adjust Font Size (DPI)
3. Choose Large Scale (120 DPI) or Custom DPI (if you want bigger font)
For Windows 7
1. On the Desktop, right click on an empty space and select Personalize, then click on Display.
2. Choose Medium or Set Custom Text Size (DPI) if you want bigger font.
Sep 07, 2011 | Computers & Internet
The font size, as seen on my screen, is too small, and I am having trouble finding out how to fix this problem. Help?
You can change the settings by right-clicking on the desktop and change the settings. In this window you can change the font size and icon size
Mar 24, 2011 | Computers & Internet
How do I increase and set font size?
First, right click on your desktop and click on Personalize. Alternatively, you can go to Control Panel -> Appearance and Personalization -> Personalization.
In the Personalization window, go to the left pane and click on Adjust font size (DPI).
If UAC is turned on you will need to make an additional confirmation so that the DPI Scaling window will launch. You can choose the default scale of 96 DPI or a larger one of 120 DPI, which makes the text more readable. If these two options are not enough you can click on the Custom DPI button and choose another size (DPI).
In the Custom DPI Setting window you can select the desired percentage for the DPI increase. You have the following options: 100% for the normal size of 96 DPI, 125% for 120 DPI, 150% for 144 DPI and 200% for 192 DPI.
If you set the DPI higher than 96, and you are running Windows Aero, the text and other items on the screen might appear blurry in some programs that are not designed for high-DPI display in Windows Vistamag-glass_10x10.gif. You can avoid this issue by using Windows XP style DPI scaling. Just check the appropriate option and press on OK.
The change can be applied only after a system restart. Close all the running applications, save your open documents and then press on Restart Now. After a reboot, the font size will be changed.
Feb 06, 2011 | Dell XPS Laptop with Intel Core 2 Duo...
How do I make my font and text size bigger?
If you want to make font and text larger in a Word document, just look at the taskbar and click font pull-down window (usually the default is Times Roman) and pick whatever font you want, then click the pull-down window (usually the default is 12) and pick a larger size.
Or you need to make a display adjustment. Click Start, Click Control Panel, Click Personalization, click Display Settings, choose Resolution up or down which will adjust icon and font size on your computer.
Or click start, Control Panel, Personalization then:
  • In the left pane, click Adjust font size (DPI). If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  • In the DPI Scaling dialog box, do one of the following:
    • To increase the size of text and other items on the screen, click Larger scale (120 DPI)-make text more readable, and then click OK.
    • To decrease the size of text and other items on the screen, click Default scale (96 DPI)-fit more information, and then click OK.
    To see the changes, close all of your programs, and then restart Windows.
  • Jan 01, 2011 | Computers & Internet
    How do i change the letter size on my acer pc/e-machine
    If you are using windows Vista, you can just simply right click on the desktop and choose personalize... At the left of your view, you can see that the is the word for adjusting the font size ( DPI ).. You can enlarge it to 120 DPI or just customize your desired size... Normally, the default is 96 DPI... Remember... the effect only happens after you restart your computer... The picture below will guide you... Hope this method will also works in other windows such as XP or 7...
    Jan 04, 2010 | Acer Aspire 5602WLMI Notebook
    Fonts too small
    personalization>appearance>advanced
    then click on what font needs to increase on the picture and change font size
    Jun 13, 2009 | Dell Dimension 2400 PC Desktop
    Adjust font size DPI to make default as 120 DPI
    go to settings and set the display settings .
    Jan 16, 2009 | HP 2133 Notebook PC
    Acer's x193w killing my eyes..please help
    First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
    Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
    Jan 02, 2009 | Acer X193W LCD Monitor
    Microsoft Windows XP Home Edition English for PC Logo
    522 people viewed this question
    Top Microsoft Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    efs_perpends
    efs_perpends
    ThaMp3Doctor
    ThaMp3Doctor
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
