Question about NetGear N600 Wireless Dual Band Router
My HP G60 laptop with Vista won't connect to Netgear router
New Netgear N600 router, and HP G60 router will only connect to the net when hardwired - can't do wireless. It worked fine with my old linksys router wirelessly. The tech tried for over an hour and thinks some third party program is blocking it. He suggested to call HP support but I can't find a number for them. Any ideas or suggestions? It works fine with my Toshiba running Windows 7 after we logged into the ISP. Thanks, Mary
Posted by Mary on
Peter Howitz
    New Friend:
    Problem Solver:
  • 8 Answers
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Posted on Jun 22, 2017
5 Related Answers
Anonymous
  • 61 Answers
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Posted on Dec 01, 2008
Anonymous
  • 35 Answers
SOURCE: Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Posted on Mar 19, 2009
Anonymous
SOURCE: mr814v2 wireless router not working with vista
I have the same router, and it works with windows vista. I didn't have to do any firmware upgrade. I just plugged it in and it works..
Posted on Apr 06, 2009
Ron Pope
  • 144 Answers
SOURCE: NetGear wireless router: my laptop won't connect after hibernate
go to a command prompt window (start, type in "cmd") once there type "ipconfig /release" (space between ipconfig and the /)
wait for it to release, then type "ipconfig /renew" (all without the quotation marks) this should work
Posted on Feb 23, 2010
Anonymous
  • 117 Answers
SOURCE: Problem with NETGEAR Wireless router WNR2000 and
1. If you can upgrafe firmware on router that can fix your problem
2. you can go to netgear website for latest firmware on router(you can download from there)
Posted on Mar 17, 2010
How do I connect my HP Photosmart C4795 Printer to my new Netgear N600 Router?
Hello Janet,
Please click Wireless printing center to access more info on how to connect you printer to a netgear router ( wireless )
Dec 23, 2013 | NetGear N600 Wireless Dual Band Router...
Dgnd3700
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 16, 2013 | NetGear DGND3700 N600 Wireless Dual-Band...
I have Hughs net HN7000S hooked up to my desktop I want to use my laptop I have a netgear N600 how do I hook it up? As o WAP or router?
You connect the ISP modem to the main port on the Netgear router. You should now see a wireless network on the laptop.
Passwords / keys / paraphrases are located in the wireless part in the web admin to the router. Same thing for the user / SSID.
Jan 08, 2013 | NetGear Computers & Internet
I connected my vizio 55 inch wireless enabled tv to a new Netgear N600 router, previously I had an older version of a router, now I cannot setup to connect to the new router
I to just upgraded to the Netgear N600 router. No problem with my iMac or 3 Roku boxes in three different rooms, but would not connect to my 22inch Vizio WiFi in the kitchen even though it could see the signal. After 3 days looking on the net, I gave the guest setup on the router a try. It worked! the Vizio sees both signals. Just select the Netgear "guest" and enter the password you set it up with. Works like a charm.
Jul 18, 2012 | Vizio XWR100 Wireless Router
Slow connection
well for this ,, go to run > type - NCPA.CPL right click on local area connections and click on properties .... a new box will appear with some content on it .... double click on internet protocol version 4 and and copy down all the content if it has ... in a systematic manner
then thrn of the router and unplug all the cables from the back of router and turn of the computer also and wait for 1 minute .... this process is called as Power cycling
ther after one minute connect all the cables back to the router and turn on the computer as well ....
then cee if the problem is resolver or not if it doesn't get threw kindly call your cable operator
..... regards
Apr 19, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
How do i hard reset the n600 wireless router to set the defaults
take a look at the back of the device. there is a tiny hole between the usb and the wifi button. use something suitable to push the button inside (pen, paper clip) and hold 5 seconds (until the power light begins to blink). release the button and wait for the router to boot up and you are with factory defaults settings.
def username is admin
def password is password
def ip address is 192.168.1.1
you can also access the router by typing www.routerlogin.net or .com
there is a link to the manual if you like to learn more
ftp://downloads.netgear.com/files/WNDR3400_SM_23MAR2010.pdf
Sep 19, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I recently purchased a Netgear N600 Wireless router connected to my Comcast Motorola Surfboard SB5120 modem. I have a Comcast plan of 20 Mbps but through www.speedtest.net am consistently getting 8 Mbps...
I think its the modem that you need to upgrade. Comcast is already running on DOCSIS 3.0 system. The SB5120 modem that you have is a DOCSIS 2.0 modem. You may need to have your modem replaced with a DOCSIS 3.0 modem like the Motorola SB6120.
Aug 31, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Hardwired working, wireless not
hi ,
u will have to increase the beacon interval of the router .... that can be done wih the help of a router setup.... or
Oct 29, 2008 | NetGear WGR614 Router
NetGear N600 Wireless Dual Band Router Logo
102 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
