Question about Pool & Spa
The motor is an aqua flow-flow master xp2.
The XP2 pump uses a 5/8" shaft seal.
You can find them as under part numbers - PS-200, AS-200 or 92500150.
Posted on Feb 29, 2012
SOURCE: My hot tub is dead. Is there a reset button for
If you have a GFCI that will have a reset. Without knowing what tub it is I can't say. Most will have a lockout that kills all power on the door. You can make sure the door is closed, use a jump wire or find the switch and use a magnet to get it to close. It's not much but I hope it helps.
Posted on May 01, 2010
SOURCE: I am looking for a
A quick google search brings up a number of online sites between $340, and $430
Posted on Sep 22, 2010
SOURCE: what windings do the leads of the capasitors get
Please reply with the motor brand, model and serial number so we can get you an accurate wiring diagram. Simply comment on this post and enter the information there.
John
Posted on Dec 10, 2010
SOURCE: I was told that the Aqua Flo Master Xp2 Spa pump
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Posted on Jan 13, 2011
Testimonial: "Thank you so much. That helps alot. Do you have any other suggestions for a pump tha might be less expensive then a Max E Pro?"
SOURCE: I have an Aqua-flo Flo-Master
Yes this is replaceable, click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 09, 2011
Nov 08, 2013 | Heating & Cooling
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Sep 28, 2011 | Heating & Cooling
Aug 02, 2011 | Coleman Powermate Powermate 5000W...
May 25, 2009 | Coleman (100076) Compact Refrigerator
Feb 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Dec 10, 2008 | Air Tools & Compressors
May 28, 2008 | Amana NAV5800A Top Load Washer
Dec 23, 2020 | Intex Pool & Spa
