Question about Jenn-Air Ovens
Where can I get a --service manual for my svd48600 Jenn-Air oven
If I use my oven for over 60 minutes - it flashes a "f" and beeps until I turn it off at the breaker.
Posted by Kate Herbelin on
Kristen Denison
    New Friend:
    Problem Solver:
  • 13 Answers
The "f" code means that there is a problem with your electronic range control or your "ERC" which is the logic board. sometimes it is simply a loose connect as they tend to be sensitive. Try wiggling the wire connections, with the appliance unplugged of course, and see if that clears up the problem. If not then you need to replace the ERC unit.
Posted on Feb 27, 2012
5 Related Answers
Priya darshan
  • 3422 Answers
SOURCE: Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Posted on Sep 17, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Posted on Jul 27, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Posted on Jul 16, 2010
Sajjad Inamdar
  • 661 Answers
SOURCE: I have a Jenn-Air Gas-electric
Hi raymond,
What you need to do now , is try to run through a setting by memory and see if you can get the oven to come on.
The problem is either of the two relay control board or the clock unit itself which is not showing any indication.
If you had any issue with the clock , i.e. it has been dim recently etc...then that could be a clock problem.
The solution is to replace any of them, If you have the feeling or any indication that the clock unit was completely ok , then you can try and run through a setting from your memory and check if the oven works , if not then most probably it's the relay control board that needs replacement.
Hope that helps..:) Let me know in case you have any queries.
Posted on Sep 12, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: Jenn-air 30" dbl wall oven ww30430w: F1 and
Hello, pearse
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
I just cleaned my Jenne Aire Expressions double oven. Now its flashing and beeping "FC" how do I turn it off?
Check your wiring harness, if its OK then replace the power relay board. A faulty board can cause fan issues and pull up the error you are seeing.
Mar 29, 2011 | Jenn-Air JJW9627C Expressions Collection...
HI,
Sep 17, 2008 | Jenn-Air Electric Double Oven
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Can't release door after cleaning
Sorry you are having trouble, unfortunately this is not an easy one to fix.
If the oven is cold then the sensor is telling the control it that oven is still hot or the control is stuck in the hot position.
There is not an easy way to unlock the oven without pulling the unit out and taking the top off to get to the latch.
I have attached a link to the service manual if you wish to attempt it.
If not I would suggest turning off the circuit breaker to the oven and letting it sit overnight. See if that will reset the issue, if not you will have a big job ahead of you or a costly repair.
Sorry I do not have good news for you on this one.
maytag_library/docs/16010191.pdf
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Jenn air touch panel on oven beeping and flashing
throw the jenn-air out.
purchase something from another company that cares about their products.
I have had the same issue, twice. my wife managed to melt the touch pad by baking and using the burner at the same time. this has happened to countless purchasers of jenn-air **** appliances. they should be sued and forced to fix their faulty design
Aug 29, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Ovens Logo
176 people viewed this question
Top Jenn-Air Ovens Experts
Michael Thomas
Michael Thomas
Nathan Van Boven
Nathan Van Boven
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
